Home > Puma (Tdci) > Location of tiny heatshield near exhaust manifold location? |
sidler Member Since: 18 Apr 2013 Location: Netherlands Posts: 12 |
I just replaced my clutch. Everything went quite ok and I managed to fit everything back into place - except one tiny heatshield that fell of the engine. It is somewhere below the larger exhaust manifold heatshield and should be mounted with some clip or so.
Could someone tell me where it comes from? If possible with a picture or so? I can't find it in the documentation I found.... Thanks! Paul |
19th May 2013 4:42pm |
Aha thanks! So this is where it should be! I already tried to put it up there but couldn't see where it should snap to, but I'll try again.
I'll see if I can get it back on tomorrow. Maybe I should just put another pop rivet in because I've read they tend to come loose... The other connectors, earth cables and breather hose are fine. I spent 1,5 hour looking for where the last cable on the top should be connected to, but after taking the cubby box and seatbox plate out on my dad's Defender I saw this cable isn't connected to anything... |
19th May 2013 9:00pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
Ha, ha! Checking my turbo heat shield fastenings to try and get rid of an annoying zingy little rattle at certain revs and hey presto I find the CPS sensor shield is loose and floating about. Unless you have hands like a debutante how the 'kin hell are you supposed to get it back on? Steve.
22nd May 2013 9:58am |
I managed to do so with a lot of swearing and kicking to the tyre - put no way I get it a tight fit. It stays loose (not the shield on the clip but the clip to the gearbox housing). As soon as I bent the clip it wouldn't go in anymore so I bent it back.
Took me about 45 mins... looks like a cheap retrofit solution |
22nd May 2013 11:09am |
Yeah it's cr@p. One of the pop rivets was pulling through the tin foil so I drilled them both out and fitted larger headed rivets with washers underneath. The bracket just sits in a fairly big void - precision engineered it is not. Steve.
22nd May 2013 12:21pm |
Some pics..
From above Click image to enlarge From below Click image to enlarge Turbo heatshield removed Click image to enlarge Click image to enlarge Removed showing crankshaft position sensor Click image to enlarge Larger pop rivets and washers fitted [dirty heads as I'd knocked the other side of the rivets down a bit] Click image to enlarge Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
22nd May 2013 4:56pm |
max peck Member Since: 30 Aug 2012 Location: Dubai Posts: 17 |
Thanks Steve.
5th Jul 2013 7:06pm |
HotelCharlie Member Since: 20 Oct 2011 Location: Kavala, Greece Posts: 25 |
Does anybody know the part number for this heatshield? Can't find it nowhere, neither can my dealer! <img>
8th Jul 2013 11:02am |
