Home > Td5 > Wastegate adjustment
johnnyd
How can I check my wastgate is set correctly/optimum, does a nanocom do it at all?
JD 2008 TDCi 2.4 XS CSW
Post #249657 7th Jul 2013 6:19am
"setup", as in, giving the correct boost? yes, nanocom will show the boost pressure.
If it's (the pressure) too low, then you can shorten the actuating rod a bit with the adjuster/locknut.
I think it's 1bar/ 14.7psi
Post #249664 7th Jul 2013 7:11am
johnnyd
Is that idle speed or across the whole rpm range, is the value constant ?
Post #249666 7th Jul 2013 7:19am
No, at idle there will be next to no boost. that value is the max boost when under full load.
try having the nanocom plugged in and switched to instrument mode (well, on my Mk1 it is instrument mode, might be called something else on your snazzy new one Laughing ) and go for a drive, watch the boost pressure, especially when gunning it up a hill, you'll see the boost raise up.
Post #249672 7th Jul 2013 8:12am
johnnyd
Ah found this......
&desktop_uri=%2Fwatch%3Fv%3Doh78RvQDbfY 2008 TDCi 2.4 XS CSW
Post #249678 7th Jul 2013 8:30am
johnnyd
Hmmm that nanocom shows turbo pressure in kpa, mine seems to be bar .......what should it not ever go over ? 1 BAR? 2008 TDCi 2.4 XS CSW
Post #249724 7th Jul 2013 12:26pm
Google is your friend..... KPA to PSI convertor
14.7psi (which is 1bar) = 101.35kpa
Post #249734 7th Jul 2013 1:19pm
johnnyd
I don't even know if its BAR how comes mine doesn't display what any units are, but the pics I see on google display units, have I missed a setting somewhere?
Post #249783 7th Jul 2013 6:40pm
What does it say in the manual that the readings are in?
Post #249785 7th Jul 2013 6:51pm
