![]() | Home > Maintenance & Modifications > Fuel tank guard for Puma 90 |
The step in your first pic above is a genuine parts step as well - it doesn't have any brackets that go under the rear cross member so I'd agree that it should fit. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
I have a NAS step, & wondered if Paddock's own guard http://www.paddockspares.com/pm748-def-90-...steel.html would fit a 08 Puma with the step. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
I'd be interested in knowing that too, if you find out pls let me know
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
The manyec one does fit with the drop plate towing gear if you modify the guard as i found out last year when i fitted mine. from memory it required about 1" from each side to be removed to enable the support bars to be fitted 2004 TD5 Defender 90 xs station wagon
Cheers, did you just cut off the excess with a grinder? Have you got a picture of it you could post please? |
Yes i used a 115mm grinder much to the disproval of neighbours
![]() I will get the pics for you shortly 2004 TD5 Defender 90 xs station wagon |
![]() ![]() ![]() ![]() I hope these help Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Thanks John, I thought you were fitting one with an NAS step though? thanks for the pictures anyway mate.
