Home > Td5 > Hi Low switch |
sc70 Member Since: 29 Jun 2010 Location: Tregaron Posts: 261 |
according to the hawkeye my 110 is in low when in high and visa versa, will this effect the driving as low is reduced throttle??
the plug on the switch only goes one way, so can i just cut and swop wires or is it a hawkeye giving incorect data www.Equi-Trek-Tregaron.co.uk Main Dealers for Equi-Trek and Brian James Trailers |
2nd Jul 2013 6:23pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Yeah the Hawkeye dose say its the wrong way round, nothing to worry about.
Pete. |
2nd Jul 2013 6:48pm |
ok cheers, so the ecu thinks its the correct way? www.Equi-Trek-Tregaron.co.uk
2nd Jul 2013 6:55pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6090 |
"Normally open", as in, the contacts of the switch are open and not touching, is "high" range.
when you select low range, the switch presses and the contacts close. I don't know why these readers all sense them back to front (I think the later generation of nanocom sorted this problem out) i'm sure BAS or IRB can explain. So, if you don't like the low range throttle response, just unplug the switch off the front of the transfer box (and put some tape over the plug to keep the poo out) |
2nd Jul 2013 7:31pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8006 |
i am surprised your not running two maps Si one on each switch setting! Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
2nd Jul 2013 8:06pm |
no map yet James this is another 110 for a bit of fun www.Equi-Trek-Tregaron.co.uk
2nd Jul 2013 8:15pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
I was told (no idea if it's right or not) that all the original aftermarket boxes were cloned from one that was reverse engineered from a Land Rover test book. The original reverse engineered version had it the wrong way around (and also the clutch switch IIRC) so all the clones had the same problem.
Some of the clones were later fixed by their suppliers but most weren't, hence the Nanocom et al still read it backwards. http://www.yorkshireoffroadclub.net/ |
2nd Jul 2013 8:29pm |
overlanding then??? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
2nd Jul 2013 8:33pm |
thats the plan, 3 door and have put a cage on www.Equi-Trek-Tregaron.co.uk
2nd Jul 2013 8:51pm |
