Home > Maintenance & Modifications > RRC hand brake on a puma ? |
Has anyone fitted a RRC handbrake to a puma ?
This was a modification I did to my td5 110, its basically relocating the hand brake to the side of the cubby, makes for easier application of the hand brake. Only the hand brake needs to be changed on a td5, the cable just needs adjusting - thats it. I got the initial idea from here: http://www.reedx.net/landrover/mods/handbrake/index.htm not a great photo but you can see it installed here, it's a little higher and back towards the cubby Click image to enlarge |
22nd Jun 2013 2:55pm |
Luismi Member Since: 04 Nov 2010 Location: Cotswolds Posts: 178 |
This going to my to do list Steve
now your leg don't lay on the handbrake isn't ? |
22nd Jun 2013 6:00pm |
sat13 Member Since: 06 Jun 2010 Location: Cheshire Posts: 70 |
I changed the handbrake lever for an RRC one a couple of years ago, on my 09 Puma 90 xs. It’s so much better relocated next to the cubby box. I set it on an aluminium plinth bolted through the floor panel, using the original brake cable set at a different angle to connect up with the new linkage. I can now rest my leg in comfort while driving. I used the original gator over the new unit. It looks quite good in the new position. When it went in for its first MOT the tester thought it was standard fit because it is an XS model, I just agreed. Also the hole left by removing the old lever was blanked off with an aluminium plate using the two tapped holes that held the original lever on.
22nd Jun 2013 7:25pm |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 |
Its on my list of things to do as well. If anyone is interested the part number is NTC2794.
Regards, Mark |
22nd Jun 2013 7:46pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6083 |
A disco handbrake lever here on eblag
Looks the same as a RRC one... £20 too. |
23rd Jun 2013 11:11am |
Did you use a lever the same as the one in the link I posted above?
(If so, I know where I can get one for mine) |
1st Jul 2013 6:02pm |
Yep
Click image to enlarge Ray Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
1st Jul 2013 6:17pm |
cool.
looks wierd with two handbrake levers! |
1st Jul 2013 6:21pm |
It did a bit! But not anymore
1st Jul 2013 6:38pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2941 |
I used a Discovery 2 handbrake
1st Jul 2013 6:55pm |
Are the D2 levers much different?
1st Jul 2013 6:56pm |
No Jim much the same as RRC
1st Jul 2013 10:10pm |
[quote="ibexman"]No Jim much the same as on the RRC plus side you can use the original rubber boot turned upside down e]
1st Jul 2013 10:11pm |
