![]() | Home > Td5 > Injector lash.... worth adjusting on service? |
Morning Jim,
From own experience two things come to mind... 'If it ain't broke, don't fix it' and 'What could possibly go wrong?' Best leave it would be my own personal advice.... ![]() Treat every day as if it is your last....one day you will be right!! |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8162 ![]() ![]() ![]() |
it will reduce ticky bit yes.
i would check it. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 160 ![]() ![]() ![]() |
Interesting. How do you do this? Any special tools needed? Or it's straight forward once you open up the head? From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 ![]() ![]() ![]() |
Half inch spanner and a flatblade screwdriver.
Just like adjusting tappets, but no need for a feeler guage... you turn the engine over (with a spanner/socket on the crank) and look at the camshaft... there is 1,2,3,4 & 5 engraved in it, but you can see when the rocker arm is at full drop. then you loosen the locknut,. turn the adjustment screw until it bottoms out, then undo it 1 complete turn. I did mine the other day, each one could be wound up by 1.5 turns, then backed off the 1 turn, so they were all 0.5 turns too "loose". the difference it made? nothing. ![]() ![]() |
