Home > Maintenance & Modifications > 110 DC spare wheel mount |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
Like the 130 ?
Can you post a pic of the bracket you made? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
17th Jun 2013 5:30pm |
Innuendomaster Member Since: 29 Mar 2013 Location: South East Posts: 230 |
I need to do something with my Spare also, tucked against the tub headboard takes up so much room.
17th Jun 2013 5:39pm |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1760 |
When it's a bit less busy in the tub I'll get some pictures |
17th Jun 2013 7:17pm |
It's a worth while mod and how it should be from the factory. Makes the rear tub a lot more useable. |
17th Jun 2013 7:20pm |
thanks. When you can... It looks like a great mod! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
17th Jun 2013 8:56pm |
+1 for the photos please.
20th Jun 2013 12:10pm |
Hopefully get the camera in there this weekend.
@ supacat, where in west yorks are you? |
20th Jun 2013 5:25pm |
PM sent.
21st Jun 2013 7:26pm |
Click image to enlarge |
23rd Jun 2013 6:40pm |
like that idea
23rd Jun 2013 6:42pm |
Managed to get a bike lock around the bracket and through the spare for better security as the locking wheel nut is worse than a normal wheel nut.
23rd Jun 2013 6:49pm |
That's quite an elegant solution and certainly food for thought over putting the spare on an external wheel carrier.
Out of interest did you look at or consider the OEM recessed tray arrangement that's available? |
23rd Jun 2013 7:27pm |
I was told about the tray but didn't fancy carving the wheel boxes and thought this was simplest solution. I am surprised the DC has the sloping wheel boxes and not the square type like in the HT.
I didn't consider swing away as it restricts loading or else I would hae got a Ute |
23rd Jun 2013 8:03pm |
Hi
Great! Did you fit any reinforcement bracket/plate under the wheel arch? Or on the edge where you have those screws?
don't see one since the SIII 109... Do you have any pics or the part number for that item? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
28th Jun 2013 9:21am |
