Home > Td5 > Pulling to one side (feels like brakes) |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6124 |
I would have thought the garage would delve deeper into the problem, but things I'd look for would be:
Tyre pressures loose wheel bearing TRE (track rod end) knackered on one/both ends of the track or drag link swivel bushes too much play (jack up and grab the wheel at 6 & 12 and try to wiggle) |
24th Jun 2013 2:03pm |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
Thanks Jim, but he's checked them all and all are fine. No steering issues, no tracking issues, all bushes are fine, all bearings are fine. Perhaps it is just this issue with the drivers side calliper causing the problem.
Just to re-iterate, it isn't a continuous thing. Most of the time it feels absolutely normal, then all of a sudden (seemingly with no input from me) it will pull quite markedly to the left. It did it this morning on the way to the garage at around 50mph and it was really quite uncomfortable. I'm not really happy driving it whilst it's in this condition. 2005 Td5 | 90 Station Wagon | Tonga Green |
24th Jun 2013 2:11pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17590 |
A stuck piston, or at least a piston which cannot be fully retracted, can usually be remedied by pushing it further out and polishing off any corrosion with very fine abrasive paper.
A stuck piston on the osf caliper is likely to cause a pull to the ns under braking. If you can hear the brakes squealing it suggests strongly that either the brakes are not releasing, or the disc is not running true in the caliper. My first suspicion therefore from what you describe would be that (in addition to the stuck piston in the osf caliper) your nsf wheelbearing is on the way out. Other possible causes and things to check include the nsf brake line and hose - if the hose is breaking up internally or the pipe has been crushed it can prevent the return flow of fluid after a brake application. If you have ABS/TC it is I suppose conceivable that a fault in the ABS pump could be causing a similar effect. Other things that can cause disconcerting steering effects are failures of the Panhard rod bushes, or the disintegration of the front diff. Having had my front diff break up and seize completely whilst driving I can say with some authority that the steering effects are unpredictable and profoundly disturbing! However the brake noise you say you are getting makes me doubt that it is this in your case, so I would check everything else first. |
24th Jun 2013 2:36pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
My TD5 did this a few times. Had new disks and pads plus wheel bearings and it was a lot better.
Had an advisory just after the work was done on the bearings so my garage said they would check them. Before it went in I noticed the OSF swivel weeping and the garage thought that the excess wheel play could be the swivel pins going. Had the work done, needed different bearing spacers and the pins were on their way out due to previous owners rigorous regime of non maintenance Now no more steering wander and on one particular section of road where it was prone to pulling to one side on braking there are no problems at all Might not have anything to do with your problem but one to bear in mind. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
24th Jun 2013 5:01pm |
Thanks for the suggestions chaps - my indy stripped down the hub this morning and discovered that the inner wheel bearing was basically stuffed. Very black with some black wear marks on the race. Now has new bearings on the passenger side and new calliper on the drivers side, new pads, new brake fluid, and all seems well again (at least in the short distance between the garage and home!). Bit of a hole in the old wallet, but at least we discovered the problem (hopefully!).
Tris. 2005 Td5 | 90 Station Wagon | Tonga Green |
25th Jun 2013 5:50pm |
Good catch! It's not completely unheard of for front wheelbearings to seize solid with spectacular, adrenaline-rich, and catastrophic results.
25th Jun 2013 10:06pm |
LRSoffroad Member Since: 15 Feb 2012 Location: Doncaster Posts: 189 |
Check panhard rod bushes can also make it pull to onside when braking
26th Jun 2013 1:10pm |
