Home > Puma (Tdci) > 08 Plate, 22000 miles and it throws a diff out! |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
If its the front put a locker in if its the back put an atb
Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
21st Jun 2013 8:41pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8024 |
Ashcroft ATB low pinion if rear
front another 4 pin but from Ashcroft. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
21st Jun 2013 9:01pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
I'm guessing it's the usual problem of a 2-pinion diff failing on an early Puma.
Irrespective of which axle, fit an Ashcroft ATB. It's cheaper than a genuine parts replacement (which will be 4 pinion now anyway) but much stronger, as well as the traction advantages of an ATB. Works perfectly in either axle with no ill-effects on steering if in front axle. If you want an even stronger diff get an Ashcroft HD ring and pinion fitted, but be aware it is likely to whine a bit under certain driving conditions. |
21st Jun 2013 9:27pm |
william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259 |
Just paid for my atb diff from paddocks(Ashcroft isn't open at weekends. hopefully get it on Monday or Tuesday at the latest.
I still can't believe at 22000 miles a diff could blow! Just as we'll I was at the house at the time William |
22nd Jun 2013 10:04am |
an ashcroft ones from paddocks? Cheers
25th Jun 2013 8:00am |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
http://www.paddockspares.com/ashcroft-limited-slip-diff-atb.html Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
25th Jun 2013 8:20am |
I would have bought from Ashcroft direct but they weren't open at the weekend and I wanted to try and get it dispatched on Saturday. Hopefully it comes today and ill post a few photos and opinions on it William
25th Jun 2013 8:44am |
