Home > Td5 > Banging from drivers side rear |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 |
just try moving rear door up/down when its open, hinges could have had it if you have spare wheel on door..Or its not adjusted properly when shut.... Putting Dreams on Drives at JLR Solihull..
16th Jun 2013 2:40pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1814 |
shock mounts, trailing arm rubbers, bonnet hinge rubbers even???
Keith |
16th Jun 2013 3:16pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
Found it.......took the spare wheel off eventually, needed a hammer on the wheel spanner, and the fixing it was on ( a black tubular locking bracket system) made a similar noise, took it for a spin and no rattle, so the weight of the spare wheel is making the bracket bang over bumps, is there a fix as it is quite annoying?
JD 2008 TDCi 2.4 XS CSW |
16th Jun 2013 3:20pm |
If its a Mantec design, cut some thin plastic discs and insert in the pivot points, then nip the pivot bolts up.
16th Jun 2013 3:36pm |
Its that style but not mantec or bearmach, here is mine
https://www.dropbox.com/s/waxy779v6jr9ytc/photo%20copy%202.JPG Edit....I think this is mine.... http://compare.ebay.co.uk/like/28111154742...mp;ff14=66 JD 2008 TDCi 2.4 XS CSW |
16th Jun 2013 4:26pm |
