Home > In Car Electronics > Antenna change
Nick-St
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
Antenna change
Anyone fitted a combined GPS/GSM/Radio Antenna on the roof? Worth the effort/enough space under the headlining?
I'm thinking of something like this:
http://www.ebay.co.uk/itm/121115293337
Post #243936 15th Jun 2013 9:52pm
Where would you fit it? I think it would look strange on the wing top. Do you have a roof rack or bars ?
Post #243964 16th Jun 2013 6:48am
Nick-St
Anywhere convenient on the roof... No bars or rack...
Post #243979 16th Jun 2013 8:13am
K9F
On the middle of the roof in-line with the rear of the front seats (where the slope stops) would be quite discreet, also with such a low profile it's unlikely to impinge on any later roof rack fit perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #243987 16th Jun 2013 8:36am
Nick-St
That's the sort of thing I was thinking... Are there any ribs underneath the headlining there? I know it'll be a pain to get the wiring there...
Post #243993 16th Jun 2013 8:50am
K9F
Not sure about reception but you could 'trial' it perhaps by fitting it to your offside wingtop blank. Wiring would be a doddle. If successful and it works you could perhaps leave it there if it looks ok? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #243998 16th Jun 2013 9:01am
Nick-St
I did consider putting it in place of the existing aerial - but though it might look a bit odd there!
Post #244013 16th Jun 2013 10:04am
There is a rib in the centre of the roof, take a look at my 130 Defender build for pictures
Post #244017 16th Jun 2013 10:18am
Nick-St
Will do - do you have a link?
Post #244030 16th Jun 2013 11:08am
K9F
http://www.defender2.net/forum/topic15815.html?highlight=130
With pictures page 1.....
http://www.defender2.net/forum/topic18533.html?highlight=rib
Amazing the search malarky...... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #244039 16th Jun 2013 11:20am
I think your right on that one too Matt. i seem to remember someone who wanted to do this and had to have it slightly off set to central. That's enough to put me completely right off. Neutral KEEP CALM AND Drill ON
Post #244045 16th Jun 2013 11:31am
barbel jim
Think it was DAB aerial placement. IIRC it was Foxkiller, who mounted his Dab offset at the the rear of the roof???
Post #244049 16th Jun 2013 11:43am
Nick-St
Found a different pic...
Looks like a central position behind the 'hoop' would work ok...
Post #244050 16th Jun 2013 11:44am
