Home > Td5 > Water Ingress |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 |
I believe that LR manufacture holes into the bodywork on the production line, to let water escape. This is the same water that has entered via gaps that arent supposed to be there...
http://www.defender2.net/forum/topic10467.html |
7th Jun 2013 3:44pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
Maybe this cider is taking effect But i don't understand that last post 2008 TDCi 2.4 XS CSW
7th Jun 2013 3:47pm |
Water on the floor/pedals is something almost every owner encounters. Most common way for water to get in is either..
in-between windscreen rubber & windscreen Windscreen/buklhead brackets and then running down the inside of bulkhead and onto the pedals. Hence the link I posted for sealing such areas. How come youve only just noticed it? |
7th Jun 2013 5:14pm |
http://www.defender2.net/forum/topic2126.h...windscreen
http://www.defender2.net/forum/topic9478.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
7th Jun 2013 6:15pm |
DRW58 Member Since: 23 Feb 2013 Location: Perthshire Posts: 167 |
I too have a similar issue, but some of mine certainly comes from the roof area, runs over the top of the drivers door, hits the door trim and runs directly into my boot on the accelerator pedal
I think it could be coming in the sun roof seal as at times it runs out from under to head lining. Just one of the joys of land rover ownership. At some point I'll remove the roof lining for a look see but there are more pressing issues at the moment. DRW I built a garage for my Mini With a place for everything and everthing in its place. Ten years down the line there's a Mini in there somewhere, and all's where it should be!!!! Ho hum |
7th Jun 2013 8:57pm |
Postmanpat Member Since: 01 Aug 2012 Location: Co.Limerick Posts: 50 |
same problem here , say a standard option ... Postmanpat
11th Jun 2013 2:10pm |
megatoad Member Since: 07 Jan 2012 Location: Hertfordshire Posts: 358 |
There is a special dispenser installed at manufacture that detects when it is raining and randomly dispenses fluid into 1 or thew other footwells.
It has an infinite supply stored in a huge reservoir located in Hyperspace. This is why Land Rover supply nice rubber mats, to protect the carpet from getting wet. He who dies with the most toys wins Defender 90 & 110, S1 80", Disco 1, S111 88 LRSOC & CVLRC |
11th Jun 2013 4:23pm |
Ah well i feel a little happier now i know its a special feature most other people have as well
JD 2008 TDCi 2.4 XS CSW |
12th Jun 2013 3:22pm |
On a less tongue in cheek post here is a link to the Land Rover official guide for technicians to try and fix leaks in a Defender
http://www.scribd.com/doc/17833628/water-ingress-manual Mine usually puddles on one or the other drivers fotwell mats. After a heavy downpour there is is usually a small amount of water that I can tip out with the mat, fortunately the carpets have only got wet once, but that was whilst I drove Violets Lane, I still have muddy tidemarks 3" up the seat boxes. and the water came up through the door seals!! The dog was NOT happy as he was snoozing in the rear footwell at the time. He who dies with the most toys wins Defender 90 & 110, S1 80", Disco 1, S111 88 LRSOC & CVLRC |
12th Jun 2013 3:33pm |
