Home > Td5 > Water Ingress
johnnyd
Water Ingress
Hi All
I have noticed that after a lot of rain and the Defender not having been used during the rain that water appears on the floor of the drivers seat by the pedals, is this normal? If not, is there an obvious route for the water to get in, i cant see any trails
JD 2008 TDCi 2.4 XS CSW
Post #241730 7th Jun 2013 3:05pm
WarPig
I believe that LR manufacture holes into the bodywork on the production line, to let water escape. This is the same water that has entered via gaps that arent supposed to be there... Mr. Green
http://www.defender2.net/forum/topic10467.html
Post #241737 7th Jun 2013 3:44pm
johnnyd
Maybe this cider is taking effect Smile But i don't understand that last post Shocked 2008 TDCi 2.4 XS CSW
Post #241739 7th Jun 2013 3:47pm
WarPig
Water on the floor/pedals is something almost every owner encounters. Most common way for water to get in is either..
in-between windscreen rubber & windscreen
Windscreen/buklhead brackets
and then running down the inside of bulkhead and onto the pedals. Hence the link I posted for sealing such areas. How come youve only just noticed it?
Post #241766 7th Jun 2013 5:14pm
K9F
http://www.defender2.net/forum/topic2126.h...windscreen
http://www.defender2.net/forum/topic9478.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #241774 7th Jun 2013 6:15pm
DRW58
Scotland 2001 Defender 90 Td5 SW Epsom Green
I too have a similar issue, but some of mine certainly comes from the roof area, runs over the top of the drivers door, hits the door trim and runs directly into my boot on the accelerator pedal Big Cry
I think it could be coming in the sun roof seal as at times it runs out from under to head lining.
Just one of the joys of land rover ownership.
At some point I'll remove the roof lining for a look see but there are more pressing issues at the moment.
DRW I built a garage for my Mini
With a place for everything and everthing in its place.
Ten years down the line there's a Mini in there somewhere, and Censored all's where it should be!!!! Ho hum
Post #241835 7th Jun 2013 8:57pm
Postmanpat
Ireland 2004 Defender 110 Td5 DCPU Bonatti Grey
same problem here , say a standard option ... Sad Postmanpat
Post #242772 11th Jun 2013 2:10pm
megatoad
United Kingdom 2006 Defender 110 Td5 XS CSW Zambezi Silver
There is a special dispenser installed at manufacture that detects when it is raining and randomly dispenses fluid into 1 or thew other footwells.
It has an infinite supply stored in a huge reservoir located in Hyperspace.
This is why Land Rover supply nice rubber mats, to protect the carpet from getting wet. He who dies with the most toys wins Smile
Defender 90 & 110, S1 80", Disco 1, S111 88
LRSOC & CVLRC
Post #242796 11th Jun 2013 4:23pm
johnnyd
Ah well i feel a little happier now i know its a special feature most other people have as well Smile
Post #242989 12th Jun 2013 3:22pm
megatoad
On a less tongue in cheek post here is a link to the Land Rover official guide for technicians to try and fix leaks in a Defender
http://www.scribd.com/doc/17833628/water-ingress-manual
Mine usually puddles on one or the other drivers fotwell mats. After a heavy downpour there is is usually a small amount of water that I can tip out with the mat, fortunately the carpets have only got wet once, but that was whilst I drove Violets Lane, I still have muddy tidemarks 3" up the seat boxes. and the water came up through the door seals!!
The dog was NOT happy as he was snoozing in the rear footwell at the time. He who dies with the most toys wins Smile
LRSOC & CVLRC
Post #242991 12th Jun 2013 3:33pm
