Home > Off Topic > Which Ride on lawnmower should I get???
Page 1 of 3 123>
mcma1
So it's time for me to buy my first ride on for the new house. Feel like I am shopping for a new car Laughing
I have looked at the following 2:
John Deere 305r �4250 new
Honda HF2417 with electric dump: �2950 new but last model so no mulching.
The husqavana seem to be a good price and has a Kawasaki engine so it should be fairly reliable, only one dealer close to me however but plan to call in today for a look.. Anyone got one?
I am swaying towards the Honda as it appears good value and I can also get a decent walk behind for the awkward bits.
Andy
Post #242681 11th Jun 2013 6:47am
hi Andy
JohnDeere's are good and hold their value.
Avoid Italian models ... look good but don't work well (lawnflite i think)
(The first one I had was from the USA, it was brilliant, but can't remember the name, even cut the grass well in the rain!)
Post #242689 11th Jun 2013 7:49am
mcma1
Yes I looked a few used JD and they were still looking strong money for them, this was the Husqvarna i was think of...where are they from?
http://www.husqvarna.com/uk/products/garden-tractors/cth-184t/
Post #242690 11th Jun 2013 7:55am
SGH
I have a Kubota GR1600-II runs on red diesel Thumbs Up
I had a Countax CH600 with Honda V-Twin but it was painfully slow and drank fuel Sad
Post #242691 11th Jun 2013 8:05am
mcma1
Yes I can get a Kubuto for just of 5k but i think its really over kill.
Post #242692 11th Jun 2013 8:10am
SGH
See if dealer will demo it you will find it's a great mower I was apprehensive on paying over �5K for a mower as first.
You also need to decide if you want to collect the cuttings or mulch only. If you collect then be prepared for a grass mountain if you have a large area to cut. Laughing
Stiga with the front decks are supposed to be good and can get around trees and in awkward places.
Simon
Post #242693 11th Jun 2013 8:15am
ericvv
I have a Husqvarna 260 something.... (forgot the exact letters combination).
It is a 26HP 750cc fuel motor, has a 54 inch side throwing mower deck with three knives, and I have about 8000 sqm of grass to cut, so quite a lot. Which takes me about 1.5 hours each week. Not exactly your english type of lawn like a golf green, less refined rougher grassland.
The machine is 4 years old now, has run about 125hrs in total, and works like a gem. One big annual maintenance done by the dealer, and one intermediate oil change by myself, and regular greasing of front axe and mower deck knives. Never had anything break down sofar. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #242696 11th Jun 2013 8:32am
camelman
Not sure why MTD / Lawnflites are being discouraged. They're cheap, I bought mine for �500 when it was a year old and that was 7 years ago. Gets used and abused every weekend and all I've had to do to it is stick a new battery on a couple of years ago.
My neighbour bought a brand new Stiga at the same time for �3k and hit has spent most if it's life back at the repair shop! I think it would be fine on a perfect lawn but as the cutting decks are out the front, the first sign of bumps and they take hit and snap the belts.....
Post #242704 11th Jun 2013 9:13am
This is mine, had it for a couple of years now and works well.
50" cut speeds things up a bit Thumbs Up
Post #242711 11th Jun 2013 9:34am
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
I have John Deere mulching tractor mower which has been great over the last 7 years or so. Ideally I would have got the single blade model but that was discontinued (a lot less to go wrong) having said that the twin blade has worked well without any problems.
It will cut nice and short for a lawn and also cut the paddocks when long (I usually shoot it out the side exit for that)
The downside of the mulching is that if you try and cut too much off it will leave grass on the cut lawn (but not much) but if used regularly at a sensible height cut then a pretty good result. As mentioned before if you collect the grass be prepared for a huge mountain of stuff, but a bag is handy for collecting the leaves in autumn. If you can get one which does mulching, collecting and shoot out the side then that would be perfect.
Toro Wheelhorse mowers are good but pricey , don't discount the lower end ones, as often they use the same motors as the more pricey ones, so have a look at the engine and see what it is. Have a look at some pricey ones first so you can compare build quality, components etc with the lower end ones when you look at them.
Buy what your budget allows really, I'm sure there are deals to be had nowadays.
Don't forget you can buy a big range of after market bits (I have a handy tipping trailer for moving logs/soil etc) plus you you can play 'farmer' for a bit Laughing
Good luck
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #242713 11th Jun 2013 9:49am
mcma1
Just been to the honda dealer so last years HF2417 2900
Then seen the Husky 184, very nice, and a 2012 model for 2200, only concern it that it has electric dump, plus they seem to get a few re calls.
Post #242734 11th Jun 2013 11:07am
mcma1
You need to re tirm that seat..
What model is it?
Post #242735 11th Jun 2013 11:11am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
I looked at getting a second hand one, and even posted a wanted add on here (many thanks to the offers I received).
However I decided to go for a new one in the end, a Mountfield MT1538M-SD and its brilliant. Nice and small and cheap too �1399.
One thing that you may want to consider is how large is the area you need to cut. In my case it was just over 1/2 Acre so didn't need anything too big. Also do you want to mulch or collect the clippings - I wanted to mulch (quicker and no heap of rotting grass).
Post #242750 11th Jun 2013 1:19pm
Happyoldgit
I got a 3 diesel cylinder Iseki - does the job. Steve.
http://forums.lr4x4.com
Post #242755 11th Jun 2013 1:42pm
Countax A2050HE - I knew someone would say something about the seat Mr. Green
Post #242761 11th Jun 2013 2:19pm
Page 1 of 3 123>
