![]() | Home > Maintenance & Modifications > Two axle breather queries |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20718 ![]() ![]() |
Yes it is.
Simply remove the pipe and if it's clear it should be fine. AFAIK there is a special technique for removing the pipe as I have done it myself but forgot how to now. ![]() ⛽️🛢️⚙️🧰💪 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17704 ![]() ![]() ![]() |
Disconnect the pipe from the axle. Check axle fitting is clear by probing with a piece of fence wire or similar. Check pipe by placing lips around pipe and blowing.
miket Member Since: 05 Oct 2012 Location: Peak District Posts: 143 ![]() |
Grand, sounds nice and simple...
Cheers Mike |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8207 ![]() ![]() ![]() |
why do you think it might be blocked? blowing oil from a gasket/seal? Cheers
Yes, there's a little oil on the inside of the brake that can't have come from anywhere else. It was an MOT fail and so my free MOT (that came with my free service at the dealer) wasn't so free after all...
It's booked in to a local garage (dealer wanted �200 just to diagnose the problem) on Wednesday. Mike |
inner hub oil seal in the back of the disc. a pretty simple task to change, wheel off, caliper off, hub off, remove old seal and replace. that particular seal is unlikely to have gone due to a blocked breather. wheel bearings are ok i take it, no advisory on them? Cheers
No advisory on anything else - thanks for the brief description of what needs to be done!
Mike |
One last question - to replace the inner hub oil seal do you need to take the half shaft out?
no
wheel off caliper off dust cap off half shaft circlip off drive member bolts out remove drive member hub nuts off (will either have one fit spacers with stake nuts or double nuts with locking tabs. fits latter on rebuild) hub off invert hub change rear seal refit as above in reverse you can leave the drive member and shaft connected with the circlip and pull the lot, nothing in it really. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Thanks James, much appreciated.
Mike |
