Home > Maintenance & Modifications > Two axle breather queries
miket
Hi
I've got a MY09 Puma 110 and as far as I can see the breather hose simply pushes into the axle breather, is this correct?
Also, what is the best way to check if the breather is blocked? Blowing air through the hose will obviously clear this, but how do you check the actual breather in the axle? Can it be removed and cleaned?
Many thanks
Mike
Post #241709 7th Jun 2013 2:47pm
Re: Two axle breather queries
miket wrote:
Hi
Yes it is.
Many thanks
Mike
Simply remove the pipe and if it's clear it should be fine. AFAIK there is a special technique for removing the pipe as I have done it myself but forgot how to now. Neutral WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #241744 7th Jun 2013 4:52pm
Disconnect the pipe from the axle. Check axle fitting is clear by probing with a piece of fence wire or similar. Check pipe by placing lips around pipe and blowing.
Post #241754 7th Jun 2013 5:04pm
miket
Grand, sounds nice and simple...
Mike
Post #241780 7th Jun 2013 7:35pm
jst
why do you think it might be blocked? blowing oil from a gasket/seal? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #241951 8th Jun 2013 12:26pm
miket
Yes, there's a little oil on the inside of the brake that can't have come from anywhere else. It was an MOT fail and so my free MOT (that came with my free service at the dealer) wasn't so free after all...
It's booked in to a local garage (dealer wanted £200 just to diagnose the problem) on Wednesday.
Mike
Post #241956 8th Jun 2013 12:58pm
jst
inner hub oil seal in the back of the disc. a pretty simple task to change, wheel off, caliper off, hub off, remove old seal and replace. that particular seal is unlikely to have gone due to a blocked breather. wheel bearings are ok i take it, no advisory on them? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #242056 8th Jun 2013 8:55pm
miket
No advisory on anything else - thanks for the brief description of what needs to be done!
Mike
Post #242300 9th Jun 2013 6:56pm
miket
One last question - to replace the inner hub oil seal do you need to take the half shaft out?
Post #242491 10th Jun 2013 12:20pm
jst
no
wheel off
caliper off
dust cap off
half shaft circlip off
drive member bolts out
remove drive member
hub nuts off (will either have one fit spacers with stake nuts or double nuts with locking tabs. fits latter on rebuild)
hub off
invert hub
change rear seal
refit as above in reverse
you can leave the drive member and shaft connected with the circlip and pull the lot, nothing in it really. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #242614 10th Jun 2013 9:39pm
miket
Thanks James, much appreciated.
Mike
Post #242632 10th Jun 2013 10:11pm
