Home > Puma (Tdci) > warning lights in dash - are there spare ones to be used? |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 |
Seat belt warning if it is not used on your model?
10th Jun 2013 8:34am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17209 |
There should be a lot of unused warning lights on the dash (since the Puma dash was lifted from Disco 3) however as far as I know they are all software controlled via the IPAC ECU, so using them may be unusually difficult if not impossible. Unfortunately I don't think that you can even find out the details from the electrical manual, although possibly looking at the equivalent manual for the D3 might give some clue.
10th Jun 2013 9:44am |
Seat belt warning is analogue switched - Pin 18 on the dash multiplug
10th Jun 2013 9:45am |
Useful piece of information, thanks. |
10th Jun 2013 10:07am |
Do some Defenders have a seat belt warning light then? Which also means that there should be a sensor in the driver and passenger seats.... Surely not in my Puma, and never heard of this feature.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
10th Jun 2013 11:34am |
You need different buckles with the switches in and the wiring
Of course, you are right. Are there countries where Defenders have such seat belt warning light with all the wistles and bells equipment it takes, probably required by law there? Not here in Switzerland, and not in the EU as far as I know. You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
10th Jun 2013 11:42am |
landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 |
@mobilecentre:
Blackwolf - that was what I suspected. So much the better that there is a simple pin to be lined up. As years pass by there probably will be more info about dealing with the more sophisticated systems. For the time being thatīs way beyond my scope. |
10th Jun 2013 2:13pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6073 |
I just looked on microcat trying to see what countries the buzzer/light equipped seatbelts are used on, but it doesn't show it, but interestingly they only seem to be available on the LH seatbelt, which would make it for LHD vehicles (driver but not passenger?)... part # EVB500990PMA
10th Jun 2013 3:27pm |
