Home > Puma (Tdci) > warning lights in dash - are there spare ones to be used?
landybehr
Hi,
is there any unused warning light in the dash that could be connected to a 12volt wire ?
If that is possible Iīd prefer it over installing aftermarket lights.
Post #242393 9th Jun 2013 10:55pm
mobilecentre
Seat belt warning if it is not used on your model?
Post #242419 10th Jun 2013 8:34am
There should be a lot of unused warning lights on the dash (since the Puma dash was lifted from Disco 3) however as far as I know they are all software controlled via the IPAC ECU, so using them may be unusually difficult if not impossible. Unfortunately I don't think that you can even find out the details from the electrical manual, although possibly looking at the equivalent manual for the D3 might give some clue.
Post #242439 10th Jun 2013 9:44am
mobilecentre
Seat belt warning is analogue switched - Pin 18 on the dash multiplug
Post #242440 10th Jun 2013 9:45am
Useful piece of information, thanks. Thumbs Up
Post #242448 10th Jun 2013 10:07am
ericvv
Do some Defenders have a seat belt warning light then? Which also means that there should be a sensor in the driver and passenger seats.... Surely not in my Puma, and never heard of this feature.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #242469 10th Jun 2013 11:34am
mobilecentre
You need different buckles with the switches in and the wiring
Post #242470 10th Jun 2013 11:34am
ericvv
Of course, you are right.
Are there countries where Defenders have such seat belt warning light with all the wistles and bells equipment it takes, probably required by law there? Not here in Switzerland, and not in the EU as far as I know. You never actually own a Defender. You merely look after it for the next generation.
Post #242471 10th Jun 2013 11:42am
landybehr
@mobilecentre: Thumbs Up
Blackwolf - that was what I suspected. So much the better that there is a simple pin to be lined up. As years pass by there probably will be more info about dealing with the more sophisticated systems. For the time being thatīs way beyond my scope.
Post #242503 10th Jun 2013 2:13pm
I just looked on microcat trying to see what countries the buzzer/light equipped seatbelts are used on, but it doesn't show it, but interestingly they only seem to be available on the LH seatbelt, which would make it for LHD vehicles (driver but not passenger?)... part # EVB500990PMA
Post #242516 10th Jun 2013 3:27pm
