Home > Puma (Tdci) > repair to defender a bar any idears
Daniel TD5
United Kingdom 1986 Defender 90 Other ST Nato Green
Rolling with laughter Rolling with laughter
went to longleat with the kids friday 13th and yes the monkeys ate my a bar its a vub td5 type
can it be fixed with a rubber compound of some sort. its a foam base with a harder rubber coating
i was hoping it could be filled in some way its about 2cm by 4cm long at the top edge
any thoughts
any way a little up date on my early TDCi double cab
still having oil leak problems
clutch and gearbox still very noisy gear change
water leaks have now started drivers foot well rear doors
i wrote a letter to the dealer rejecting it two month ago which is still on going at present they seem to be putting thair heads in the sand but land rover seem to be help full
dan
Post #2413 15th Jun 2008 3:51pm
