Home > Puma (Tdci) > De-cat pipe needed?
HMARR
De-cat pipe needed?
Hi all, I'm a new member and just bought a 2010 Stationwagon which I'm stoked about. I'm looking at all the threads here about De-cat pipes and removing the centre muffler etc, which I'm keen to do. Out here in New Zealand it's a bit harder to get these de-cat pipes and the freight is worth more than the parts as I'd have to get it shipped from UK at about one hundred quid for freight alone. I'm wondering, can I just take of the catted pipe from the turbo, punch out the cat material (thinking long concrete cutting drill-bit, chisels ? ) and fit it back on? Will this do the same thing? Cheers... Hamish
Post #240895 4th Jun 2013 1:09am
Caterham
Hamish
glad you're enjoying .. oh and so envious of your location albeit shipping might be expensive.
I'm no good on doing searches but if you have a go I'm sure you'll come across other threads where exactly what you've described has been done. and to the best of my knowledge has worked fine.
good luck.
Thumbs Up
Post #240903 4th Jun 2013 5:43am
K9F
Caterham wrote:
I'm no good on doing searches Thumbs Up
Cool I may be able to help!
YES! Thumbs Up
Page 4 with pretty pictures..... Thumbs Up
http://www.defender2.net/forum/topic15424....p;start=45 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #240933 4th Jun 2013 9:17am
RobKeay
I have one I brought from BAS and never fitted.
Post #240944 4th Jun 2013 10:55am
ZeDefender
Embarassed Haven't done mine yet either Embarassed
Too many projects on the go at once, many of them "wife-related" Rolling Eyes Tell someone you love them today because life is short.
Post #240948 4th Jun 2013 11:57am
Naks
Hamish, you can remove the cat, drill out the contents and re-fit. Save the bucks for more beer Thumbs Up --
Post #240953 4th Jun 2013 12:17pm
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Does the noise increase at the back? i want to hear some turbo Twisted Evil
And i presume mpg will increase and it will rev slightly easier? William
Post #240959 4th Jun 2013 12:48pm
Naks
I can't say that I can hear the turbo more, but then it's been bucketing so hard here it's hard to hear anything else. Confused
I also cannot correlate increase in mileage/drivability since I also did the BAS v2 remap at the same time. --
Post #240960 4th Jun 2013 12:57pm
HMARR
Thanks for the feedback guys. Zedefender - those are great pictures from the 2012 thread... but I'm a bit confused as you've said you haven't done yours yet... - have you drilled it out but not fitted it yet?
Post #241043 4th Jun 2013 7:35pm
HMARR
Oh another question. When I remove and refit my prop shaft, should I be using a torque wrench to tighten back up? If so, does anyone know how tight? I'm a bit of a novice when it comes to these things - but looking forward to getting messy with my defender... cheers, Hamish
Post #241044 4th Jun 2013 7:41pm
jst
just do them up tight. prop shaft tool from difflock helps alot too. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #241116 5th Jun 2013 5:30am
HMARR
Ok so I drilled out the cat material - lots of mess and dust. Quite an easy job and results are great. I also got the mid-box silencer removed and a new piece of pipe welded in. Second day driving it and has a real noticeable difference. More pull, turbo appears to spool up quicker - as everyone else commented it would. Strange thing is it doesn't sound any different - I would have thought that removal of the mid silencer would have made more of a throaty but it hasn't... wondering if the decat downpipe would make a difference here vs me just punhcing out the material of the existing pipe (with the bulge in it). Someone suggested I take off the battery leads for 24 hours to let the ECU 'reset' to a new exhaust system... ? Anyway, sound aside I'm pleaased with it. Remap next!
Post #242602 10th Jun 2013 8:21pm
jst
sounds promising then.
wasnt Zaks going to do to de-cat tests? does anyone know if they were done? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #242609 10th Jun 2013 8:35pm
