![]() | Home > Maintenance & Modifications > What's the best oil and how much |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5938 ![]() ![]() ![]() |
I would speak to Opie oils and see what's suggested. 1999 Defender TD5 110
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
I put Fuchs Titan sintofluid sae 75w 80 in my r380. It made a big difference as it was crunching a lot between 1st and 2nd. This problem was solved by changing the oil and the whole box was smoother. I don't know how old the old oil was though so standard land rover stuff may well have done the trick.
Forgot to say, I bought is from opie oils
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4784 ![]() ![]() |
I used this in my Puma 2.4
http://www.micksgarage.com/proddetails.asp...p;pk=EA876 Main gearbox 2.2 litres at service oil change or 2.4 litres dry fill at factory. Transferbox 1.6 litres. http://total-gbr.lubricantadvisor.com/advi...2f5afe4d02 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
Hmm if always filled to bung in transfer box and I use LSD combine oil in there
Gearbox it just been rebuilt so should it be 2.4 ? Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
If the gearbox is empty then 2.4 litres. Seems filling to the bung is not recommended on the gearbox on the Puma as one does on older Land Rover gearboxes. Seems it (filling until it runs out the bung) can lead to overheating on the Pumas. Might be something to do with the slight angle the gearbox sits at. 1982 88" 2.25 diesel
Yes only do hat on the transfer box anyway cheers spud fun 2015 2.2 tdci hardtop xs
