Home > Puma (Tdci) > Puma 90 standard speaker sizes
do any of you know what the identical standard size speaker is on a 90 Puma is for a direct replacement of standard to after market? I'm guessing 10Cm? thanks Cool
Post #24075 11th Feb 2010 12:28pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
You're guessing correct. Thumbs Up I fitted 10cm Pioneers last week and they fitted perfectly. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #24076 11th Feb 2010 1:00pm
screws lined up okay? did you use orininal speaker holes and screws?
Post #24077 11th Feb 2010 1:07pm
MrFlips
I wasn't expecting it to go as simply as everything lining up, but surprisingly they did - I used the same holes and screws. They could have been made for the job. The only thing I had to do was crimp a spade onto the connecting wire supplied in order to retain the original Land Rover speaker connectors incase I ever want to swap back. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #24078 11th Feb 2010 1:32pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi MrFlips, do you know if the Alpine system is ok with the standard fit speakers (no power rating in the handbook for them) as funds are low and cannot afford new speakers just yet. Cogito ergo sum
Post #24080 11th Feb 2010 1:48pm
MrFlips
I imagine it would be very easy to blow the standard speakers with anything with a decent amount of power. I had to replace my speakers as one had totaly blown and the other was very much on the way just from using the standard stereo. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #24088 11th Feb 2010 4:22pm
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
10 cm Pioneer Speakers
Mr. Flip,
Can you elaborate on the 10cm Pioneer you fitted e.g. model, type, back or front fitted and any other info.
Does it make a difference to the 'noise'? without having to change the original radio?
Would welcom this info.
Joe
'El Pepe Flamenco' JLS
'El Pepe Flamenco'
Post #24090 11th Feb 2010 5:13pm
MrFlips
Hi Joe. I've got a truck cab, so only have the standard speakers underneath the dashboard (and standard tweeters). I replaced my standard speakers with Pioneer TS-G1002i speakers. (http://www.pioneer.eu/uk/products/25/131/201/TS-G1002i/index.html). They're fairly low priced at £29 a pair. Sound-wise the mid and high range is very good, and better than the standard speakers. In terms of bass they could do with a bit of help from a subwoofer if you are listening to very loud music, but on the whole I am very happy with them. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #24104 11th Feb 2010 10:33pm
jlerra
Pioneer Speakers
Hi Peter,
Thanks for that valuable info on speakers, if it's a question of no-mods and the sound is better it's worth £29. I would probably need 4 as I have the 90 with front, rear and tweeters in the truck. I'll give it a try.
Thanks for your help.
regards
Joe
'El pepe flamenco' Bow down JLS
'El Pepe Flamenco'
Post #24117 12th Feb 2010 9:51am
is it possible to have some speakers that are of the deeper type but with a smaller magnet would that help?
Post #24150 12th Feb 2010 6:30pm
jlerra
Speakers
Hia Peter and 'Konabike',
Just fitted the rear and front speaker replacing the standard Land Rover speakers with the Pioneer TSG1002i. A doddle to fit front and rear - just fits in without mods.
The sound quality when front and rear are done is remarkably improvement in sound! Much better mid, high and low range and added base to match. Takes 10 minutes to do a pair without wire changes.
Totally recommend these affordable and great speakers.
Now I can drive back from Gib through Spain to UK with reasonable 'sound'.
Thanks, Peter, for your information.
regards
Joe
'El pepe flamenco' JLS
'El Pepe Flamenco'
Post #24158 12th Feb 2010 8:56pm
MrFlips
Excellent Joe. Glad you're happy. Very Happy Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #24163 12th Feb 2010 10:28pm
Naks
Hi guys,
do you know if the rear speaker housing can take 6x9's without major mods?
I've got a set of JBL's sitting at home and don't want to waste them Smile
Post #24990 24th Feb 2010 7:17am
K9F
Naks wrote:
Hi guys,
Just replaced my standard ones yesterday with some 10cm co axial two-way JVC CS-V426 ones. Rear ones needed to be spaced a little as the grilles on the JVC ones are slightly bigger than the standard recesses, just used some plastic washers. No expert but a little mutton geoff as my missus keeps telling me happy with the end result and sound quality improvement and for less than £40. In layman's terms I can now crank up above 30 with no discernable distortion.
The rear trim would have to be cut to accommodate your 6 X 9s Naks. Relatively easy and enough room I reckon. Whip the trim off and size up! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #25383 28th Feb 2010 10:45am
Naks
thanks, found a solution.
The chap who is doing the drawer system will also make 2 speaker housings, angled from the back bulkhead. Will post some pics when the drawer system is fitted Smile
Post #25389 28th Feb 2010 11:44am
