Home > Technical > Noise killer |
Velcro....Wider stuff we use at work the adhesive stick like sh....to a proverbial blanket! If you go through life with your head in the sand....all people will see is an ar5e!!
3rd Jun 2013 9:03am |
Cakey Member Since: 19 Feb 2013 Location: Cheshire Posts: 468 |
Now I thought about that . Will give it a try .
Thanks |
3rd Jun 2013 9:06am |
Welcome.
Scotch heavy duty or 3M is the stuff we use. I just used some on my waterproof electric junction boxes under my seats and it is really strong stuff. Linky fingy: http://compare.ebay.co.uk/like/31041237146...amp;ff19=0 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
3rd Jun 2013 9:11am |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
Now that could set a new trend velcro sound insulation
3rd Jun 2013 9:22am |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
@k9f
That's what I used to secure my sub to the back of the cubby. It is fixed very firmly, cant move it at all. Good stuff BM52 |
3rd Jun 2013 9:55am |
I've just bought some looks like a handy item
3rd Jun 2013 9:56am |
Done
Looks like it will hold the car together its very strong . Thanks again |
3rd Jun 2013 10:14am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
I replaced those pieces with Dynamat for the same reason...When I get around to it, I'll use double-sided tape to put the NK back over the top of the Dynamat... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
3rd Jun 2013 11:40am |
+1 I just discovered the stuff - amazing how these adhesive thingies have come on in recent years Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
3rd Jun 2013 12:23pm |
One of our contractors use a double sided adhesive clear gel type tape, it's about 5mm wide and 2-3mm thick, they use it to stick signs up. We had to remove the Costa Coffee sign on one of our vessel bulkheads and it took two of us to pull it off due to the risk of the sign breaking before the tape giving. The adhesion was amazing. I'll see if I can get a brand name. If you go through life with your head in the sand....all people will see is an ar5e!!
3rd Jun 2013 12:40pm |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 |
@K9F Thanks for the link. I had the same problem - Noisekiller sold me some heat resistant adhesive spray when I mentioned the problem to them - needless to say that fell off too! Will try the 3M stuff.
3rd Jun 2013 5:16pm |
@cobs
know what you mean, same here but I did not buy their glue. instead I have Dynamat under the bonnet, in the footwells, bell housing, under the roof and will change the seat box and rear at some point... If you need some check out the forum offer, MPS deliver Dynamat quickly and efficiently and at a good price BM52 |
3rd Jun 2013 6:58pm |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 411 |
by the way we are a sign supply company and the stuff you are looking for is red gel tape. It is clear and comes with a red paper backing. It is real permenant stuff. Alternativly look on ebay for red gel tape.
We also sell a silicon tube type adhesive and its called stix-all, about 6 qwid plus vat a tube, it is bloody good stuff!!! i use it for everything including diff sealing, bellhouseing sealing and sump sealing. Beat that for a all rounder. |
6th Jun 2013 12:27pm |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
I have just noticed the same on my 110 i used carpet glue to stick carpet to the lower parts and now the sun is out its not stuck Im going to try some RTV sealer spread on with a pallet knife and hopefully it will stay put. Pete |
6th Jun 2013 12:41pm |
