Home > Technical > Noise killer
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Noise killer
Had this fitted in march makes a huge difference .
The small issue is the bits that are below the windows the curvy bits , keep falling off. Nk replaced with new but when the sun comes out (yes I know ) they drop off , tried impact adhesive no good , carpet adhesive about the same .
Any ideas of something that will not work loose ?
Thanks
Post #240652 3rd Jun 2013 8:53am
K9F
Velcro....Wider stuff we use at work the adhesive stick like sh....to a proverbial blanket! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #240659 3rd Jun 2013 9:03am
Cakey
Now I thought about that . Will give it a try .
Thanks
Post #240660 3rd Jun 2013 9:06am
K9F
Welcome. Thumbs Up
Scotch heavy duty or 3M is the stuff we use. I just used some on my waterproof electric junction boxes under my seats and it is really strong stuff.
Linky fingy:
http://compare.ebay.co.uk/like/31041237146...amp;ff19=0 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #240666 3rd Jun 2013 9:11am
SGH
Now that could set a new trend velcro sound insulation Laughing
Post #240673 3rd Jun 2013 9:22am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
@k9f
That's what I used to secure my sub to the back of the cubby. It is fixed very firmly, cant move it at all. Good stuff Thumbs Up BM52
Post #240680 3rd Jun 2013 9:55am
SGH
I've just bought some looks like a handy item Thumbs Up
Post #240681 3rd Jun 2013 9:56am
Cakey
Done
Looks like it will hold the car together its very strong .
Thanks again
Post #240685 3rd Jun 2013 10:14am
MartinK
Re: Noise killer
I replaced those pieces with Dynamat for the same reason...When I get around to it, I'll use double-sided tape to put the NK back over the top of the Dynamat... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #240702 3rd Jun 2013 11:40am
ZeDefender
+1
I just discovered the stuff - amazing how these adhesive thingies have come on in recent years Thumbs Up Tell someone you love them today because life is short.
Post #240709 3rd Jun 2013 12:23pm
K9F
One of our contractors use a double sided adhesive clear gel type tape, it's about 5mm wide and 2-3mm thick, they use it to stick signs up. We had to remove the Costa Coffee sign on one of our vessel bulkheads and it took two of us to pull it off due to the risk of the sign breaking before the tape giving. The adhesion was amazing. I'll see if I can get a brand name. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #240711 3rd Jun 2013 12:40pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
@K9F Thanks for the link. I had the same problem - Noisekiller sold me some heat resistant adhesive spray when I mentioned the problem to them - needless to say that fell off too! Will try the 3M stuff.
Post #240756 3rd Jun 2013 5:16pm
bm52
@cobs
know what you mean, same here but I did not buy their glue.
instead I have Dynamat under the bonnet, in the footwells, bell housing, under the roof and will change the seat box and rear at some point... Rolling Eyes
If you need some check out the forum offer, MPS deliver Dynamat quickly and efficiently and at a good price Thumbs Up BM52
Post #240798 3rd Jun 2013 6:58pm
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
by the way we are a sign supply company and the stuff you are looking for is red gel tape. It is clear and comes with a red paper backing. It is real permenant stuff. Alternativly look on ebay for red gel tape.
We also sell a silicon tube type adhesive and its called stix-all, about 6 qwid plus vat a tube, it is bloody good stuff!!! i use it for everything including diff sealing, bellhouseing sealing and sump sealing. Beat that for a all rounder. Thumbs Up
Post #241433 6th Jun 2013 12:27pm
bell-auto-services
Re: Noise killer
Thanks
I have just noticed the same on my 110 Sad i used carpet glue to stick carpet to the lower parts and now the sun is out its not stuck Sad
Im going to try some RTV sealer spread on with a pallet knife and hopefully it will stay put.
Pete
Post #241436 6th Jun 2013 12:41pm
