Home > Wheels & Tyres > Sankey Trailer Wheel Size
Myers
United Kingdom 2013 Defender 90 Puma 2.2 HT Epsom Green
Aftwrnoon all
I've just collected my Sankey Wide Track, it tows really well but is a lot higher a the tailboard end. I had the NATO hitch on the highest setting on the slider bar as well, defender is standard height wise.
The current wheel set up is Michelin Synchrone 235/70R16 on what looks like eight spoke steel wheels, the tyres also stick out from the wheel arches by approx 2 inches.
Does anyone have any recommendations for a setup the will reduce the ride height and keep the tyres inside the arches??
Thanks in advance
Post #240447 2nd Jun 2013 2:33pm
Innuendomaster
Get some hub adapters for the Sankey and you can then use the same wheels as the Defender. That"ll reduce the nose down effect. More extreme is you can extend the A Frame upto 600mm, the length will have the same effect as well as greatly improve towing
Post #240454 2nd Jun 2013 3:04pm
Trossachs turbo
Scotland 2005 Defender 90 Td5 CSW Oslo Blue
Attach your NATO tow jaw to the top four holes in your rear cross member,remove the spare tyre,to accommodate the jockey wheel.I have also seen the tow jaw on the trailer fitted upside down on the underside of A frame and the brake connection point inverted to suit.I have done the former and find a better tow and weight distribution.some people retain the lowered towing braket for other 50mm tow hitches.Regarding the tyres they must be non standard as mine do not project.
Post #240461 2nd Jun 2013 3:29pm
The older trailers (mk2, 3 etc, often all called "Sankeys") had 6.50x16 tyres on old series-type SWB rims.
The newer ones have 7.50s, usually on Wolf XD HD rims, but neither of those tyres stick out mch, if any, from the arches.
I suspect the 8 spoke you've got has a large offset, hence why they're sticking out.
i've seen some people use the old lightwheight series3 "plastic wheelarch" kits on sankey type trailers, doesn't look too bad.
Post #240465 2nd Jun 2013 3:50pm
Standard wheel/tyre size is a 7.50 x 16, which is the same diameter as a 235/85 16 on a modern Defender. 235/70 is standard for a Disco I or Range Rover and is slightly smaller.
Which type of wide track is it? If it's a disk braked MkIII then the hitch is mounted within the depth of the A frame and, when attached to a Dixon Bate on the highest setting, will tow level, like this:
However, if it's a drum braked MkII then the hitch is mounted on top of the A frame and will tow 'nose down'. Darren
Post #240466 2nd Jun 2013 3:58pm
SGH
I'm on the lookout for a disc braked wide track Thumbs Up
Post #240467 2nd Jun 2013 4:17pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
"I'm on the lookout for a disc braked wide track"
Aren't we all!
Peter
Post #240473 2nd Jun 2013 4:54pm
SGH
Aren't we all!
Peter
Rolling with laughter
Post #240474 2nd Jun 2013 5:04pm
landy andy
Any more details Jamie?
Fancy the idea of wheel arches like my defender has got, rather than the big square hole of the Sankey.
Andy
Post #240525 2nd Jun 2013 8:38pm
It was this kind of thing Andy:
Available from Simmonites I think, if you've got a spare kidney and left arm.
Can't find any google image pics of a sankey with them fitted though.
Post #240577 2nd Jun 2013 10:22pm
landy andy
Post #240596 2nd Jun 2013 11:03pm
pjh
Ah, that will be our truck Very Happy The Sankey was modified by Foley's:
http://foleysv.com/here-we-have-a-mod-sank...and-travel
Although they only did the bottom half! The rest are listed here:
http://www.defender2.net/forum/topic19520.html
Kind regards,
Peter Defender 11MY USW
Post #241344 5th Jun 2013 10:41pm
landy andy
Very very very nice that, got a lot to do to mine.
Can I be bothered Rolling Eyes Rolling Eyes
Andy
Post #241379 6th Jun 2013 7:30am
