Home > Puma (Tdci) > making hole to gain access to fueltank |
mog Member Since: 27 Feb 2011 Location: Århus Posts: 26 |
Hello Guys
Has anybody tried to make a square hole in the bottom of a puma to gain access to the top of the fueltank. I know it was done to the TD5 to get to the fuelpump. There is no fuelpump in the puma, but I have a leak and would like to avoid taking the tank down. What I am looking for is some measurements where to cut and what tool to use (how deep to cut without risk) Thank you in advance Morten |
31st May 2013 12:22pm |
I'd drop the tank personally. Safer and no 'butchery' that you have to fix/seal afterwards. If you've a leak the last thing you want to do is grind out a hole. Not a difficult task. If you go through life with your head in the sand....all people will see is an ar5e!!
31st May 2013 12:27pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1788 |
Been looking for photos I took when I did the above - to fit a fuel dip tube for an Eberspacher.
Its pretty easy to see under the arch where the fuel sender is and get a measurement from the rear edge of the floor, its front edge is approximately in line with the rear floor brackets for the rear seat. Its left hand edge is in line with the floor strengthening rib on the left. I very carefully (with a stop on the drill bit to prevent drilling too far through the floor) drilled a small slot to enable access then gently opened up the hole with aviation snips, a Monodex cutter would also work well. After the work on the sender, I simply cleaned the area well, then siliconed a patch of alloy plate over the top, can't even see the outline through the mat. Good luck Keith |
31st May 2013 7:46pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
I've done it on a TD5 90, not sure how different that would be. As I had no idea what room I had between the tank and the floor at the time I got a piece of steel plate and slid it over the top of the tank as a shield.
As it turned out there was a lot more room between the floor and the tank than I'd expected in the area I was cutting. I started with a 50mm hole cutter roughly in the middle of where I thought I needed to be then used the angle grinder to cut the rectangle out. An angle grinder is a good option for cutting because it needn't go through the floor more than a mm or 2. http://www.yorkshireoffroadclub.net/ |
31st May 2013 8:07pm |
Thanks for the ansvers guys
1st Jun 2013 4:41am |
The 99% of the car have it.....
http://www.ilmiodefender.altervista.org/botola90.pdf This is the dimensions dornthe 90 And http://www.ilmiodefender.altervista.org/botola110.pdf For the 110 I done it on my 90 for add the Webasto pickup and I am happy with it, a lot more easy operations for maintenance...... Easy to remove mud and sand from the tank...... I done a square hole and the cap is closed by scews and rivnuts (and appropriate seal) Need remove the rear carpets for take samemphotos if you want...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
1st Jun 2013 10:12am |
Thank you very much dgardel that was exactly what I was looking for
I can see that you also have a puma so did you find the measurements to be precise ? and what kind of tool did you use (how much space is there) ? I cannot tell you how much I appreciate this help/feedback Morten |
1st Jun 2013 10:27am |
Yes the measurements are correct for the td5 and Puma Mind that the measrements for the 90 are different from the 110. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
1st Jun 2013 10:58am |
Here
http://www.ilmiodefender.altervista.org/botola_pompa.htm Same photos from a friend of mine. I preferred the square shape secured with screws and threaded inserts On the web page posted there is the dimensions for build the tool for unscrew the fuel sender ring also Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
1st Jun 2013 11:02am |
