![]() | Home > Puma (Tdci) > QT diffguard fitting |
Tried 'Googling' only decent one I could find:
Linky fingy: http://www.reads4x4.com/qt_diff_guards.htm If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
I think there's a body behind the 90 in your link K9F
![]() 1968 1/32 scale Britains 109 Pick up. |
![]() ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 ![]() ![]() ![]() |
The instructions are daunting - I had a set delivered to the office yesterday, and along with removing the track rod catcher on the front you need to rejig the brake-pipes on the rear to avoid rubbing. They're sitting in the office until my confidence is up to tackling them. Peter
2008 SWB Truck Cab 1952 80" Soft top |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
Don`t panic
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Sonic, did you have any brake pipe problems when fitting?
No problems with brake pipes at all
Rock on! I took the old Rebel4x4 guard off when Foley waxoyled the 110. Theyreally only offer superficial protection against small stones and earth.
I'm going to put the QT on when I go to Wales next at the end of the month. I'll try to take some useful pictures for others who might be attachng QT guards. ![]() |
Chunk Member Since: 19 Oct 2009 Location: County Durham Posts: 154 ![]() ![]() ![]() |
It really is straight forward guys, I found that for the front one it was easier to loosely bolt on the top bracket to the diff guard then hook that over the top studs before bolting up the bottom. You'll see what I mean when you come to fit it.
Back one was more or less straight forward apart from it being awkward to reach the top nuts on the back of the diff whilst lying on the ground. Soon found a workable position and it was ok. As Sonic points out getting the holes on the side of the diff case lined up might be a bit fiddly but the Mk.1 persuader soon gets it lined up. I found it easier to unbolt the brake pipe junction thingy to the right of the diff to get the pipes out of the way then put it back on when finished. It's only an 8mm bolt onto a bracket if memory serves. All in all about an hour it took me just on the drive outside the house. |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
i found that to line up the holes on the side of the guard/diff it help'd to have the rear bolts done but not tight then a bottle jack under to push it up and around, but thats me, but think yourself lucky i got no instructions and the first one was the wrong type
As doublecabhappy said some suppliers send out the wrong type
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
Timely post - my guards arrived today and I read the instructions in horror.
It wasn't even clear to me what the the two thin brackets that I received were for. It's obviously dark now so this is a job for the weekend. Will take piccies as I go. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
look in my gallery Al
I found this ![]() Click image to enlarge Still can't see the little galvanised brackets though. ![]() + New Defender 110 First Edition |
