Home > Technical > High Level Rear Brake Light on MOT
chopdogs
Hi Guys
Wondering if you'd know whether a high level rear brake light not working would cause an MOT failure?
The bulb is fine - looks like the edging strip inside the door that carries the electric current is corroded. Had a chap try to fix it with some special gunk but no joy. He suggetsed a new rear window - which seems a touch OTT
Thanks
Post #26441 10th Mar 2010 4:03pm
Glynparry25
That is 50:50, will depend on the inspector.
A high level brake light isn't needed for an MOT (same as reverse light).....but as with the reverse light, if it has one, it has to work. Can you take it off for the test?
Glyn Sheep
Post #26443 10th Mar 2010 4:12pm
Glynparry25
Oh,
if you decide to change the rear window, check your insurance as if you have glass cover it will only cost you the £50 excess to have it replaced Wink
Glyn Sheep
Post #26445 10th Mar 2010 4:14pm
dgardel
Italy
The problem for the rear heated glass is the 3rd stop tail rubber.
probably it release rubber solvent that "eat" the heated element
Dealer changed me the rear windows two times.
Now I cutted (below) the rubber (5 on the figure) and make same sockets (where are 90° tracks curves and stop carries) for avoid contacts from the heating tracks and the rubber.
Now the problem seems solved...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #26465 10th Mar 2010 8:02pm
chopdogs
Short term solution to pass the MOT - piece of wire linking the high level light with the clip at the bottom of the window.
Works fine - though it may end up in a fireball at some stage.......... Whistle
Post #27941 24th Mar 2010 6:43pm
adiep
Gibraltar 2008 Defender 110 Puma 2.4 SW Alpine White
Does anyone know where I can buy this part? my back light is broken and needs replacing, is it possible?
Post #212862 20th Feb 2013 10:34pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Morning all,
some advice please, my high level rear brake light not working yet again Big Cry , have already had two windows replaced under warranty (which has now run out Big Cry ) have checked bulb filament and it appears ok, taken of the fitments and checked all around the 'elements' and they also appear to be ok as in no breaks etc, checked fuses ,ok, is there something else I should be checking or could the element be broken elsewhere? is there a quick fix or does it look like another rear window replacement? thanks in advance. Cogito ergo sum
Post #239642 30th May 2013 8:58am
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
sounds like another rear window Rolling Eyes Crying or Very sad
Post #239646 30th May 2013 9:25am
Paul55
Unnecessary quote removed
Big Cry Cogito ergo sum
Post #239649 30th May 2013 9:31am
Porny
Site Sponsor
I have a brand new never fitted 12MY brake light spec rear window for sale, with the latest heater element design... will be less than a main dealer. Can have it fitted as well if needed.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #239680 30th May 2013 11:43am
spudfan
Ireland
Mine stopped working a while age. The cause was a short break in the element beneath the foam insert. I made a temporary repair by bridging the break with a piece of copper wire held in place by some heavy duty tape. As this is covered by the foam insert it is not visible. And as the old adage goes -Out of site out of mind-, the "temporary" repair is still in place and the high level break light is still working. The hardest part is finding the break, as it is usually about a millimetre or so. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #239681 30th May 2013 11:44am
Paul55
Ian
PM sent Cogito ergo sum
Post #239683 30th May 2013 11:45am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
I think you will find that if the 3rd brake light is there it must work,however if it "permanantly removed" then it will pass.Have removed one from on of our family cars some years ago and not had an issue at M.O.T time. 2005 Td5 90 XS
Steve
Post #239751 30th May 2013 5:11pm
landybehr
From 1998 the EU insist on new cars having the 3rd brake light. You might get away with removing one. GermanTÜV probably will notice and let the car fail the MOT-Test.
But on a local forum a guy wrote he simple took a lenght of common elect. wire and put it behind the window seal so you don´t see it and thus he "bridged" that broken connection. That´s more reliable and and worth an imitation in case you would have to pay yourself for a new window.
Post #239776 30th May 2013 7:56pm
DAZ110
That's how mine has been for the last few years! Rolling Eyes
Post #239780 30th May 2013 8:14pm
