Home > My Defender > New 110 |
Looks like a great (also as in "large") job.
Seriously though, will you really end up with a "quiet" vehicle at the end of it? Our family (me, wife and 4 teenage children) have driven about 10,000 km in our 110 on holidays and no-one (!) has ever made a serious complaint about the noise... However, if it would give me the peace and quiet I associate with Mercedes taxis, I would be seriously interested Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
25th May 2013 4:31pm |
Carling switches Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
25th May 2013 8:47pm |
Have you a link from where you bought the brackets from please? Be interested in purchasing a set myself.
Thank you. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
29th May 2013 6:24pm |
a13x Member Since: 25 Sep 2011 Location: Burton on Trent Posts: 553 |
Flatdog
29th May 2013 6:45pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Looking good a13x, thank you for the order
30th May 2013 9:27am |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3787 |
So, the JW Speaker Headlight were just a bolt in.....no mods required at all....just take the OE units out & put in the JWs......and they still work with the headlight levelling, same as originals?
From what I've read, these headlight inserts seem to be as good as you can get? Cheers, Pickles. |
30th May 2013 9:38am |
+1
As an added bonus, when I fitted mine I found out LR had fitted one of the lamps the wrong way round and the leveling didn't work properly. Now everything works perfectly - I would NEVER go back to standard lights Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
30th May 2013 10:21am |
Up to near Northumberland for a few days
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
2nd Jun 2013 11:28am |
A little more done today.
Carried on soundproofing, this time used foam on top of the Dynamat Click image to enlarge Click image to enlarge Then all went back together and TGE panels installed. Quick test drive and much quieter. Roof lining will come back out once a roof rack is purchased as will feed in a reverse camera and rear lights. Undecided whether to trim the headlining black too. Will get some finished pics up. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
25th Jun 2013 5:28pm |
jayaway44 Member Since: 04 Nov 2011 Location: Edinburgh Posts: 111 |
Hi there can you give us some details on the foam on top of the Dynamat set up, where did you get the foam and is it just a spray adhesive you used.
Thanks 2.2 2012 110 utility Orkney Grey Also Range Rover Evoque - Surprising but I like it. Previous Freelander 2 SD4 HSE - Black 90 TD5 Discovery 3 Early Discovery. |
26th Jun 2013 8:35am |
cozz Member Since: 15 May 2013 Location: nottingham Posts: 541 |
so i need to take off my rear trim panel to do some sound proofing
are they easy to remove ? |
29th Jun 2013 6:35pm |
Innuendomaster Member Since: 29 Mar 2013 Location: South East Posts: 230 |
Loving the Jw Speaker lights, definately on my list when I'm off to Kentucky. Plenty of sellers are putting me off as they "they are not European versions" if bought in the USA. However speaking to JW Speaker they can supply what I want in Euro spec
29th Jun 2013 6:41pm |
