Home > Puma (Tdci) > Brake Pad Rattle on Puma |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20298 |
When were your pads last changed? âï¸âï¸God Bless the USA 🇬🇧🇺🇸 âï¸âï¸
27th May 2013 8:45am |
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 262 |
I am not sure. The truck had done 56,000 when I brought it and its now done 59,000 and has rattled since I had it. The Pads front and back look quite thick so I don,t think they are original. It could be that who ever did the pads did not put a dad or copper grease on them or fitted the shims wrong.
I plan to pull them apart for a look, but wanted some suggestions first. Tony 2008 Defender 110 XS CSW Volvo S60 T8 Triumph 1200 Rally Explorer G0UBX |
28th May 2013 7:18am |
It'd be worth doing a search but I remember at least one person solving it by putting a blob of weld on the back of the pads, which seemed a bit extreme to me Darren
28th May 2013 7:30am |
It could be that they just need lubing up on the parts required such as the pins. It may also not be helped by perhaps* thy are cheap aftermarket pads which don't have anti-rattle shims. I've got a set bought just the other day EBC Green stuff and they have anti rattle shims. Will post a photo if it helps? âï¸âï¸God Bless the USA 🇬🇧🇺🇸 âï¸âï¸
28th May 2013 9:42am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2637 |
Are you sure its the pads that are rattling and not the brake shields? --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
28th May 2013 10:12am |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
Slightly OT but do the EBC Green stuff pads give a better 'bite' when braking?
Now I have converted to auto I am finding the brakes a tad weak at times due to more use of brakes on hills etc and in traffic BM52 |
28th May 2013 10:15am |
Not sure yet as I haven't got them fitted. From what I've heard they must be good and so thought I'd give them a go. Click image to enlarge Click image to enlarge Click image to enlarge âï¸âï¸God Bless the USA 🇬🇧🇺🇸 âï¸âï¸ |
28th May 2013 10:19am |
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 719 |
I had the same rattle / clunk. I changed the pads for the latest LR version with no further problems.
28th May 2013 10:58am |
Thanks for all the replies, I am as sure as I can be that its one or more of the Pads, the rattle is on bumpy roads and seems to stop when braking, no more rattle with the brake pedal pressed.
I will investigate the cost of genuine Landrover replacements as done nidge n I think. Thanks again to all for the replies. Tony 2008 Defender 110 XS CSW Volvo S60 T8 Triumph 1200 Rally Explorer G0UBX |
28th May 2013 11:22am |
Around £118 there about's for a full set all in on a 90. I have found with my current pads (soon to be changed) that they are making the more regular squeak or noise as they have got older and reduced life. A progressive age thing really. Just seems to get worse not better. âï¸âï¸God Bless the USA 🇬🇧🇺🇸 âï¸âï¸
28th May 2013 11:48am |
