Home > Puma (Tdci) > Brake Pad Rattle on Puma
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
I have seen it mentioned that on early Pumas the brake pads rattled, I have a 2008 and I think that the rattle I have is from the brake pads, when I press the brakes it stops.
What I can't seem to find is any mention of a suitable fix, doe anyone know if its the pins or the anti rattle shims, should they be replaced or just taken out and tweaked.
Thanks Tony 2008 Defender 110 XS CSW
Volvo S60 T8
Triumph 1200 Rally Explorer
G0UBX
Post #238882 27th May 2013 8:08am
When were your pads last changed? â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #238900 27th May 2013 8:45am
Swollock
I am not sure. The truck had done 56,000 when I brought it and its now done 59,000 and has rattled since I had it. The Pads front and back look quite thick so I don,t think they are original. It could be that who ever did the pads did not put a dad or copper grease on them or fitted the shims wrong.
I plan to pull them apart for a look, but wanted some suggestions first.
Volvo S60 T8
G0UBX
Post #239126 28th May 2013 7:18am
It'd be worth doing a search but I remember at least one person solving it by putting a blob of weld on the back of the pads, which seemed a bit extreme to me Confused Darren
Post #239128 28th May 2013 7:30am
It could be that they just need lubing up on the parts required such as the pins. It may also not be helped by perhaps* thy are cheap aftermarket pads which don't have anti-rattle shims. I've got a set bought just the other day EBC Green stuff and they have anti rattle shims. Will post a photo if it helps? â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #239164 28th May 2013 9:42am
Naks
Are you sure its the pads that are rattling and not the brake shields? --
Post #239171 28th May 2013 10:12am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Slightly OT but do the EBC Green stuff pads give a better 'bite' when braking?
Now I have converted to auto I am finding the brakes a tad weak at times due to more use of brakes on hills etc and in traffic BM52
Post #239173 28th May 2013 10:15am
Off Topic Not sure yet as I haven't got them fitted. From what I've heard they must be good and so thought I'd give them a go. Thumbs Up
Post #239176 28th May 2013 10:19am
nidge n
I had the same rattle / clunk. I changed the pads for the latest LR version with no further problems. Thumbs Up Thumbs Up Thumbs Up
Post #239183 28th May 2013 10:58am
Swollock
Thanks for all the replies, I am as sure as I can be that its one or more of the Pads, the rattle is on bumpy roads and seems to stop when braking, no more rattle with the brake pedal pressed.
I will investigate the cost of genuine Landrover replacements as done nidge n I think.
Thanks again to all for the replies.
Volvo S60 T8
G0UBX
Post #239191 28th May 2013 11:22am
Around £118 there about's for a full set all in on a 90. I have found with my current pads (soon to be changed) that they are making the more regular squeak or noise as they have got older and reduced life. A progressive age thing really. Just seems to get worse not better. â­ï¸â­ï¸God Bless the USA 🇬🇧🇺🇸 â­ï¸â­ï¸
Post #239210 28th May 2013 11:48am
