Home > Maintenance & Modifications > Steaming up
Bill2812
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Epsom Green
Steaming up
Hi all I require some help
I have a 2009 110csw xs and when I turn on the heater it mists up big style?
In facts it's bloody dangerous you have to stop.
I have been told by a mate it may be water in the
I had something like this in an old car several years ago were the heater rad leaked but that was easy to spot as there was water leaking into the foot well.
I have checked as best I can the floor is bone dry and no water coming in or leaking?
Any thoughts on what it could be or how to cure it Question
Bill
Post #238861 27th May 2013 6:51am
Bill,
2 things you can do ..
> open the bonnet and drain any water in the heater intake, there are 2 rubber nipples at the bottom of the plastic housing. they block up, these can be removed.
> buy a snow cowl, this stops rain entering your heater intake. Not to everyone's taste but they do fulfill a function if you leave your truck outside all the time. They are available from SGH (site sponsor) for about £30, other sponsors also sell them
welcome to land rover ownership Thumbs Up
Post #238862 27th May 2013 6:54am
landy andy
As said above. It will be water in the heater inlet duct. There are rubber teets fitted, but these need to kept clear.
Or removed, so are never a problem again.
Follow bit plastic pipe from wing grill, to bulkhead, teets are on the bottom of this pipe.
Andy
Post #238872 27th May 2013 7:30am
K9F
I notice you've an XS it could also be the air conditioning drain underneath the vehicle. Some people (myself included) have cut the rubber drain teet to prevent it from clogging. Lift any mats you may have and see if the carpets may be damp. With the mats in it can look dry but often is the case they're wet underneath.
Good luck. Thumbs Up
Thread here follow the link in my first post on this thread:
http://www.defender2.net/forum/topic14463.html?highlight=footwell If you go through life with your head in the sand....all people will see is an ar5e!!
Post #238885 27th May 2013 8:13am
Bill2812
Steaming up
Followed advice removed rubber plugs they were blocked a fair amount of water came out
The plug for the heater is a big thing surprised that was blocked.
Great lads cheers another bit of knowledge gained
Thanks for the quick replies Thumbs Up Thumbs Up Thumbs Up
Bill
Post #238903 27th May 2013 8:59am
K9F
Glad you've had a result. Hopefully your steaming up days are over. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #238937 27th May 2013 12:28pm
