Home > Td5 > Speedo calibration |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6112 |
My 110 and 90 also does the same thing.
If i fit my 255/85's, then the speedo is spot on with the GPS |
25th May 2013 8:11pm |
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 |
This may help
Land Rover 90/110 speedo drive gears • Colour: blue/20 teeth - Part number: FRC3310 - Tyres: 7.50/16 or 235/85/16 • Colour: green/21 teeth - Part number: FRC3311 • Colour: yellow/22 teeth - Part number: FRC3312 - Tyres: 205/16 tyres • Colour: red/24 teeth - Part number: FRC3313 |
25th May 2013 8:14pm |
You can change the speedo drive for one with more or less teeth, calculate the correct ratio / number of teeth according to your measurements.
90/110 speedo drive gears frc3310 blue ------- 20 teeth -- 7.50,235/85 or 255/85 tyres 20D & 22D transfer box frc3311 green ------ 21 -- all 90 vehicles excepth the 50th ann edition. frc3312 yellow ----- 22 -- 90 with 205 x 16 tyres frc3313 red -------- 24 -- 32D transfer box Discovery 1 [200Tdi/V8] frc3310 blue ------- 20 -- diesel frc9339 ------------ 23 -- [see note] frc3310 blue ------- 20 -- V8 efi frc9339 ------------ 23 -- V8 twin carb Note frc9339 diesel for gulf states vehicles,no colour code listed, auto trans Tdi vehicles Edit: @dorstsmith2: I have to learn to type faster! Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
25th May 2013 8:21pm |
snap in hare and tortoise, tortoise always wins
25th May 2013 8:23pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Thanks for the replies, I guess I'll have to remove/look at the one on the car at the moment and work out which one I'll need, will the one from the original 90 Def box fit and read ok or will the gearing make it read wrong? Sorry if that doesn't make sense. |
25th May 2013 10:30pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
If your original transfer box read correctly then just use the speedo drive gear from that one. The speedo drive is on the output of the transfer box so the ratio of the transfer box has no effect on the speedo. http://www.yorkshireoffroadclub.net/
25th May 2013 10:43pm |
Ok, thanks davew, that makes sense, cheers for the reply. |
25th May 2013 10:47pm |
What colour speedo drive is fitted now? Cheers, Vincent
25th May 2013 10:51pm |
Not sure, I've not taken it out to look at it to be honest, I just swapped the sensors over, black to green.
25th May 2013 10:53pm |
Think it will be OK iff you put in the original speedo drive from the Disco transfer box. Cheers, Vincent
25th May 2013 11:04pm |
You mean the one out of the defender box?!! |
25th May 2013 11:07pm |
Sorry, yes the original from the Defender tbox. Cheers, Vincent
25th May 2013 11:25pm |
thanks VeeTee, I'll do it tomorrow. So, does that mean that my mileometer is out too at the moment? If so, I'm getting 10% better fuel economy than I thought? |
25th May 2013 11:45pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
I think in most cars you will find the GPS is 5mph in front of your clocks most car company give as much as 10% on clocks
My yaris reads 70?but GPS reads 64-65 Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
26th May 2013 10:26am |
