Home > Puma (Tdci) > High revving on 2007 2.4 |
Just edited post above. Why not drop Lorryman a 'pm' perhaps? If you go through life with your head in the sand....all people will see is an ar5e!!
25th May 2013 8:38am |
Frenchy90 Member Since: 17 Apr 2013 Location: Surrey Posts: 29 |
Will do
25th May 2013 8:41am |
Be interesting to hear what the root cause of your revving may be. I too leave mine (also a 2.4) standing for great lengths of time (only 1,900 miles last year between MOTs) but don't suffer the same affliction. Let me/us know how you get on!
Good luck and apologies for first post! Wasn't helpful at all really. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
25th May 2013 8:44am |
It's happened twice now but once running its faultless. If it happens again I will try and remember to post up the fault codes maybe that will help. No worries it's only banter. |
25th May 2013 8:53am |
I went to send lorryman a pm but it said no user by that name.
Found him! |
25th May 2013 9:03am |
Lorryman100
25th May 2013 9:08am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
The FCX130 is doing the same thing having been sat for 4+ months without being started so I would be interested in update once you have one please
25th May 2013 11:41am |
Faulty clutch switch???? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
25th May 2013 12:15pm |
