Home > Technical > how does the hand brake work
Page 2 of 6 <123456>
farmer giles wrote:
my very first instruction in land rover driving 20+ years ago was NEVER try a handbrake turn in a LR!
"they don't work like normal cars"
And why FFRR's cant J Turn if spung by Air Rolling with laughter
Post #237762 22nd May 2013 3:12pm
ZeDefender
Miserableolgit wrote:
A simple tweak of the adjuster to give the shoes sufficient clearance way from the drum is all that it takes to get it sorted.
...or not...
After 2 years, I have discovered Puma drums are famous for not being round Rolling Eyes and rattling/banging/scraping on various occasions (especially when hot) no matter how they are adjusted. If it happens, applying the handbrake after stopping will centre everything so it quietens down for a while.
X-Brake (disc replacement) is the only permanent solution - even our German LR mechanic knew about it Thumbs Up Tell someone you love them today because life is short.
Post #237767 22nd May 2013 3:30pm
Andy Jeff
United Kingdom 1999 Defender 90 Td5 CSW Chawton White
The most important thing I was taught about the transmission brake (other than don't try handbrake turns of course) was if possible, don't leave your car parked with it on in the winter. If it gets moisture in it (inevitable in the winter on wet roads) and it freezes on over night, you're all but Censored come the next morning. To that end, if I'm not on a hill, I'm in the habit of leaving it in gear rather than using the handbrake.
Andy.
Post #237774 22nd May 2013 4:16pm
Caterham
zedefender !
amazing. not being round would I imagine explain the reason for different amounts of adjustment !
I wouldn't have thought this possible - are we quite sure your mechanic has it right?
do you have an x-brake now fitted?
the handbrake works well enough (in so much as it stops the truck rolling) so I guess for me buying a 'round' drum would do the trick?
I presume there must be others on hear that have come across this problem?
Post #237846 22nd May 2013 8:56pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Its not a problem its an idiosyncrasy. 2005 Td5 90 XS
Steve
Post #237854 22nd May 2013 9:11pm
Happyoldgit
The drum will soon go even more out of true if the shoes have been rubbing. Steve.
http://forums.lr4x4.com
Post #237957 23rd May 2013 9:13am
Caterham
more out of true Shocked
Steve,
I know I could rely of you to cheer me up!
Laughing
more sleepless nights.
Post #237967 23rd May 2013 10:48am
Just imagine the nightmare that could be if the hand brake fails and your pride and joy goes on it's own little jolly and finishes up into a wall. Then the aftermath of insurance pain and anguish. Razz TheThunderRollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #237973 23rd May 2013 11:17am
Leave it in gear ....
Post #237974 23rd May 2013 11:20am
ZeDefender
My banging transmission brake was the reason I joined LandyZone two years ago in the first place - thank God I switched to this forum and found other similarly-suffering members. Also a LR mechanic in Colchester came to the same conclusion... after being played the sound on my phone Cool
After losing sleep fretting about gear/transfer boxes etc., LR fitted two(!) new drums (both original and 1st replacement rubbed unevenly - saw them myself) and eventually managed to minimise the problem with careful adjustment. It still makes some banging/rubbing metal noises after longer trips - doesn't bother me, since I know what it is and that it's fairly harmless. The X-Brake is sitting in the loft until the warranty runs out Whistle
One thing I realised is that the transmission brake affects the whole driveline. Since it was "improved" my problems with the gearbox kicking back when selecting third gear have also drastically reduced Smile
Matt Tell someone you love them today because life is short.
Post #237997 23rd May 2013 12:40pm
Caterham
started 'playing' with the hand brake adjustment and things have improved no end.
I suspect I should be going back to LR to sort the problem but that simply scares the hell out of me.
having never taken one of these apart or seen an exploded view don't know what to expect exactly but I presume if theres uneven ware this can only be due to the fixing points being off centre - I presume there isn't any adjustment in terms of centralising the drum?
is it easy to whip the drum out for a little look?
thanks
Post #243222 13th Jun 2013 1:36pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Yes. Instructions here http://www.x-eng.co.uk/instructions/new/x-brake.pdf Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #243260 13th Jun 2013 4:32pm
Happyoldgit
Only as far as this bit though Wink
Quote:
First remove your rear prop shaft.
Slacken off the adjuster on the rear of your existing
handbrake drum. This will make it a lot easier to
remove the drum.
The Hand Brake drum is secured by two countersunk screws which you will need a big screw driver
to remove. Remove the screws and pull the drum
off.
Besides the above you could always download the LR manual kindly provided by dgardel. Steve.
Post #243262 13th Jun 2013 5:15pm
Happyoldgit
Plus unless you've got decent thin walled sockets you'll need patience to undo the propshaft nuts, having one of these makes it a bit easier
http://www.difflock.com/buyersguide/tools/lr_propshaft_tool.shtml
Smile Steve.
Post #243264 13th Jun 2013 5:18pm
Sockpuppet
and
and
So the answer is who knows? The holes in the rear cross member could be for anything!
Post #243272 13th Jun 2013 6:44pm
