Home > Puma (Tdci) > Break Fluid at Second Service
CapeLandy
South Africa
Just had my second service done (40K) even though I have only clocked 29K they insisted on doing the 40K to keep the warenty as the anual service was due after 12months.
I see they never changed the break fluid as mentioned in the schedule I have from the forum somewhere.
Have any of you guys had the break fluid changed at the 2'nd service or is it because my mileage is too low?
I also had the radiator removed to check for leaks but they said they found none. Hope they never tried to repair it Neutral
When I got home the expansion tank was near empty Shocked I assume the mechanic never drove the truck until warm to open the t-stat and remove the air from the system. Absolute Idiots.
Now I have to drive to the parts dept. and probably pay for another bottle as the service guys are not in today. Mad
Post #23711 6th Feb 2010 7:21am
Grockle
they should have changed the brake fluid James as you thought,top up the header tank with 50/50 antifreeze water mix to the line marked on the tank. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #23717 6th Feb 2010 10:25am
CapeLandy
South Africa
Update
Just got back from Dealer - the parts dept. called out the mechanic on duty who first went through the job cards and found they removed the side tanks of the radiator and cleaned out the cores which according to them were blocked and re-soldered the tanks to the core.
He then took me home and filled up my header tank with a full liter of coolant and gave me a spare bottle. He says these Pumas are a Censored to bleed as there is no actual bleeding screw like TD5 etc. and their test route of 10km should have opened the thermostat enogh to remove any airlocks.
I also asked him about break fluid and he said 3 years between changes.
Oh well - hope the water level will stay put now. Big Cry
Post #23718 6th Feb 2010 10:36am
Grockle
fingers crossed Thumbs Up 2.4 90 XS
Post #23722 6th Feb 2010 1:09pm
MK
Do you know for sure any 50/50 mix on the market would work? or is there any other super special-hard to find mix?
thanks
M Puma 110" SW
Post #23723 6th Feb 2010 2:05pm
CapeLandy
South Africa
This is the one you should use to top up. ZAR100/liter
Post #23740 7th Feb 2010 6:09am
