Home > Maintenance & Modifications > Spacers fitted plus black wheels etc (a few Pictures!)
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Been busy recently!
Fitted some 30mm spacers (Bulldog ali version - nicely made by the looks of it) before and after pics:-
So Looks a bit more chunky and mad a good improvement to the turning circle, no rubbing now! Been meaning to try these for ages.
Also now have black wheels and bonnet logo for a change (that was a surprise for Mrs H when she got home Laughing
Also gave it a good clean.
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #236798 19th May 2013 9:26am
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Thumbs Up
Post #236799 19th May 2013 9:34am
Very smart Thumbs Up
Is that the process we were talking about ?
Post #236803 19th May 2013 10:21am
d j hutton
It is indeed, very happy with the results Very Happy
Buy British 🇬🇧
Post #236805 19th May 2013 10:37am
Killer90
Site Sponsor
Thumbs Up Nice is it plastidipped Mr. Green CSK Automotive
www.cskautomotive.co.uk
Post #236808 19th May 2013 11:19am
Green Machine
Did you remove the bonnet letters DJ? Or just mask them up very carefully? Notice you painted your wheel nuts too! Looks smart. Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #236810 19th May 2013 11:35am
d j hutton
Well spotted Chris Thumbs Up
Got to be the easiest way to change things, mask off the surrounding area, do a bit of prep work, spray a few coats - light coats so you get a smooth texture, I went a bit heavy on the letters , hence the slight texture (wheels are smooth though) let it dry for a bit (2 fags and a coffee is plenty) then peel off the excess. It cuts itself neatly around the letters as long as you have done light coats. It takes a few days to cure properly, then apply some wax and jobs done. The beauty of it is you can peel it off when/ if you get bored, but in the meantime it's a durable finish and will survive pressure washing, and chemical wheels cleaners etc.
I have done a bit of testing and although it can be peeled when you want, it is no more susceptible to scratching etc as a clear coat and paint would be - especially with the right curing and waxing.
The downside is its like hens teeth in uk, easy to get in USA . I got mine from Alan at mattpack - he's imported it direct from USA.
Dj 1989 200tdi 90 csw
Buy British 🇬🇧
Post #236949 19th May 2013 6:50pm
d j hutton
Forgot to say, nothing was removed from the vehicle so quite straightforward, I guess if you had to take a wheel off/change tyres then you might sustain damage , but easy to do another coat, plus I haven't changed a tyre in seven years so hopefully that'll continue Very Happy
Buy British 🇬🇧
Post #236977 19th May 2013 7:34pm
Killer90
Site Sponsor
Top job matey, it doesn't last aswell on the whole vehicle Laughing trust me i have tried it, but wheels and bonnets look great and lasts a while CSK Automotive
Post #237015 19th May 2013 8:19pm
d j hutton
Thumbs Up Cheers Killer, I'd be interested to see pics of the full vehicle dips you've done Chris as you don't see many landrovers done with it (I've seen the black one you peeled off the next day and the single panel on the blue 90 already) how long does it usually last in your experience? I'm thinking it might be nice to do a full dip on my 90 as the paints not looking too clever, obviously need to get the correct sprayer as doing a whole car with rattle cans isn't advised.
Full cure in this climate would be probably be a week or so (3-4 days in sunny Florida) or so I'm told by my buddy out there.
Just for interest, if it lasts on a bonnet, why not the whole vehicle?
Coverage wise a kit to do up to 19" wheels is four cans of the USA spec product, I ended up using just on three for a 16" boost, that's about 10 coats, the American experts usually suggest 4-6 coats of black. Got a pretty decent layer, judging by the peelings from the bonnet.
Quite a fun product to use really Very Happy
Buy British 🇬🇧
Post #237053 19th May 2013 10:11pm
great mod Thumbs Up
DJ - are you thinking of stocking it ?
Post #237085 20th May 2013 6:43am
d j hutton
bpman wrote:
great mod Thumbs Up
Cheers Steve (easy as well)
I did consider stocking it as I have used it for a couple of rifle stocks as a change from hydrographics, but space is a bit restricted so probably not (although I do have a couple of full cans on the shelf Whistle )
Buy British 🇬🇧
Post #237146 20th May 2013 11:41am
