![]() | Home > Maintenance & Modifications > Spacers fitted plus black wheels etc (a few Pictures!) |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Been busy recently!
Fitted some 30mm spacers (Bulldog ali version - nicely made by the looks of it) before and after pics:- ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge So Looks a bit more chunky and mad a good improvement to the turning circle, no rubbing now! Been meaning to try these for ages. Also now have black wheels and bonnet logo for a change (that was a surprise for Mrs H when she got home ![]() ![]() Click image to enlarge ![]() Click image to enlarge Also gave it a good clean. DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2039 ![]() ![]() ![]() |
Very smart
![]() Is that the process we were talking about ? |
It is indeed, very happy with the results ![]() DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Well spotted Chris ![]() Got to be the easiest way to change things, mask off the surrounding area, do a bit of prep work, spray a few coats - light coats so you get a smooth texture, I went a bit heavy on the letters , hence the slight texture (wheels are smooth though) let it dry for a bit (2 fags and a coffee is plenty) then peel off the excess. It cuts itself neatly around the letters as long as you have done light coats. It takes a few days to cure properly, then apply some wax and jobs done. The beauty of it is you can peel it off when/ if you get bored, but in the meantime it's a durable finish and will survive pressure washing, and chemical wheels cleaners etc. I have done a bit of testing and although it can be peeled when you want, it is no more susceptible to scratching etc as a clear coat and paint would be - especially with the right curing and waxing. The downside is its like hens teeth in uk, easy to get in USA . I got mine from Alan at mattpack - he's imported it direct from USA. Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html Last edited by d j hutton on 19th May 2013 10:11pm. Edited 1 time in total |
Forgot to say, nothing was removed from the vehicle so quite straightforward, I guess if you had to take a wheel off/change tyres then you might sustain damage , but easy to do another coat, plus I haven't changed a tyre in seven years so hopefully that'll continue ![]() Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Top job matey, it doesn't last aswell on the whole vehicle
![]() Full cure in this climate would be probably be a week or so (3-4 days in sunny Florida) or so I'm told by my buddy out there. Just for interest, if it lasts on a bonnet, why not the whole vehicle? Coverage wise a kit to do up to 19" wheels is four cans of the USA spec product, I ended up using just on three for a 16" boost, that's about 10 coats, the American experts usually suggest 4-6 coats of black. Got a pretty decent layer, judging by the peelings from the bonnet. Quite a fun product to use really ![]() Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
great mod
![]() DJ - are you thinking of stocking it ? |
Cheers Steve (easy as well) I did consider stocking it as I have used it for a couple of rifle stocks as a change from hydrographics, but space is a bit restricted so probably not (although I do have a couple of full cans on the shelf ![]() DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
