Home > Puma (Tdci) > Puma 2009 Defender Towing
wmca
Australia 2009 Defender 110 Puma 2.4 SW Stornoway Grey
Hi, for those interested I have a 2009 110 Puma 2.4 and currently are in Darwin NT (Australia) It is averaging 34 degree�s here and very hot.
I have towed a Jayco van for nearly 4400k�s so far and on way to Broome. I am using Mobil 1 engine oil (0-30) synthetic in engine, and fully synthetic oils GL5 in diffs and transfer, (GL4 Penrite synthetic) in gearbox. So far it has done a faultless job the van is 21ft and the vehicle has long range tank and carrying about a tonne payload all up with van GVM is about 5.5 tonne GVM. It has cruise control fitted and I am using it 98% of the time. Fuel consumption is 15.25 litre/100 in 5th gear and in 6th gear 16.5litre/100. The only concern currently is a grinding in the transfer on the �float�, (it is 34 degree�s here and this only happens when in use for around one hour onwards) no other noises when on overrun and or power on. It is the only vehicle I have seen so far towing a big van on this trip and of course is looked down upon by 200 diesel V8�s drivers, Most tugs on the trip seem to be Narvara, Ranger, BT50�s and Nissan Patrol. I am not sure the reason for not a lot of 200 series on the road, our roads used to be inundated with them, may be the cost, mine was about $50.000 fitted up for the trip.On most forum�s ALURO included don't seem to discuss Defender towing, but for very steep and or very long hills I do not notice the van on the rear.
I have around 7000 klm�s to go towing and so far happy with its performance.
Post #236506 18th May 2013 7:21am
Re: Puma 2009 Defender Towing
What speed are you doing in each gear to get worse economy in the higher gear?
Post #236531 18th May 2013 9:15am
wmca
In answer to speed in gears, both occasions traveling same type of territory and doing 85-95 k/hour. All with cruise control engaged and temp at around 34 degrees.
Post #236735 18th May 2013 11:17pm
RobKeay
When I am towing a big load I find sixth a little too higher gear at times. There used to be a mod on R380 gearboxes (300tdi&td5) to fit a better cooling system for hot countries. It may be worth investing in a better gearbox cooler to be on the safe side.
Post #236743 18th May 2013 11:40pm
