Home > Wheels & Tyres > Spare wheel swing away arms
Nick-St
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
Are they worth it?
I haven't even taken delivery of the 110 yet - but I'm looking for things to buy already!
I've been recommended to get one by another Defender owner - I can see the weight of the wheel isn't going to do great things for the door hinges over time...
Any particular ones to avoid / look at? They seem to vary dramatically in cost between £200-£800. It'll be 99% standard road use...
Post #236270 17th May 2013 10:37am
K9F
Search reveals.... Thumbs Up
http://www.defender2.net/forum/topic20067....swing+away
http://www.defender2.net/forum/topic19438....swing+away
http://www.defender2.net/forum/topic19873....swing+away If you go through life with your head in the sand....all people will see is an ar5e!!
Post #236277 17th May 2013 10:55am
Egghead
800 quid! You could buy a Defender for that Mr. Green
Post #236280 17th May 2013 11:06am
Nick-St
Thanks for the links... A couple of thumbs up for the really cheap ones (although they can rattle), a few more thumbs up for the mid-price Mantec (although they can rattle!) and a thumbs up for the Kaymar - although it's just under £800!
Seems like the Mantec is a good starting point... At least I can get the VAT back!
Post #236281 17th May 2013 11:17am
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
I have a mantec one and I'm happy, only done one winter though so not sure how well the coating will hold up but I can sort that at a later date. As for any rattle, if you add a extra rubber washer and spend time setting it up you will not have any rattle from it.
Pete.
Post #236299 17th May 2013 12:17pm
Tiger
Happy with my Mantec one Thumbs Up
Post #236301 17th May 2013 12:26pm
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Ditto Thumbs Up
Post #236303 17th May 2013 12:45pm
Nick-St
Just ordered the Mantec one... Thanks for the replies! (Just need the 110 now!)
Post #236305 17th May 2013 12:49pm
Re: Spare wheel swing away arms
Nick-St wrote:
Are they worth it?
I think the scale of this problem has become a bit overblown over the years. In Series Land Rover days, when the rear doors were only fitted with two hinges, it's true that they did suffer after a while. This was particularly true when used in places like Africa where vibrations from bad roads took their toll. As a result of this, Land Rover fitted three hinges on later models, which certainly helped.
More recently (eight years or so?) Land Rover have been using a re-engineered rear door, which is much stronger than the original.
Basically, unless you're planning to fit monster wheels or trek fully loaded across the dark continent, then it's probably overkill. Darren
Post #236306 17th May 2013 12:50pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I've been thinking about one of these swing away wheel carriers, I know its a daft question but - when opening the back door, is there a release mechanism/catch of some kind or does it just slide away easily when opening? Do they take all the weight off the back door?
Post #236307 17th May 2013 12:53pm
ericvv
Post #236309 17th May 2013 1:00pm
Tiger
Hang bikes and a wheel off mine though* Thumbs Up
* It does have a trailer board also, just in case LRA (Trailer board police looks)
Post #236310 17th May 2013 1:02pm
Tiger
The Mantec one takes maybe 95% of the weight off the back door. If you don't connect the piston, which allows the back door and the wheel carrier to open as one the wheel is happily supported on the carrier alone. (you have to connect it to the door though or it would just swing around on it's own)
So yes, with Mantec one open the back door and the wheel swings away with it as one, no extra catches no hassle.
Post #236312 17th May 2013 1:06pm
Lambley
Thanks Tiger, I'll have to work out if I could mount one with a tow step too, that takes up some of the mounting holes on the x-member
Post #236314 17th May 2013 1:13pm
kzycnn
They're compatible with NAS rear steps. I have both fitted to mine.
Tony
Post #236318 17th May 2013 1:23pm
