![]() | Home > Maintenance & Modifications > Radio & centre dash removal guide (picture heavy) |
Great write up Steve
![]() Slight hijack !! GM TD5 dash is very easy to remove. First make sure you have some small containers to put the screws in so you can put them back in the same place. Also, a small stubby cross head screw driver is useful. Remove the two end caps, the drivers end is easy as you can see all the screws. Passenger end needs the LR oval removing with a fine screwdriver to reveal one of the screws. Remove both the plastic demister vents on the top (two screws each) and then the large cross head screws in the top - five in total I think. The top of the dash will now come off, you may need to use a little force. You can now see the three screws at the top of the centre panel, just loosen them as the centre slides off, and then remove the two bottom screws and the centre comes away from the dash. If you need to remove the plate from the centre panel that holds the radio in there are spring clips that need releasing with a small screwdriver. The springs run along the top and bottom are do take a bit of time to release. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
excellent, clear instructions steve.
![]() i do agree with the old man from the north (aka Leeds) about having a technical library with no chit chat, though. ![]() |
Brilliant mate, well done !
![]() The only thing I would add to help people is that all the electrical plugs are different so no need to stress over marking them all up |
you mean a read only technical libary Russell 2011MY 110 XS USW Black |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20626 ![]() ![]() |
And I don't know if you've noticed before but from the harness each plug appears in the positions you'd expect in relation to the positioning of it's switch on the dash. That makes it a lot easier. I only marked the electric windows down because I found removing these first allowed the dash to be freed more so gave more room to remove the rest. Also appreciate that XS owners with heated seats and headlight leveling would also have extra plugs / wiring behind there too. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Anvil Member Since: 16 Jan 2009 Location: Milan Posts: 21 ![]() ![]() ![]() |
Hey Steve I've just seen it. Crystal clear Great Job ! ![]() |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3656 ![]() ![]() ![]() |
excellent very usefull thanks DEFENDER 90 TDCI XS,
I use the technical read only library on LR44 - about time there was one here
Anvil - Thank-you hope it helped.
And yes agree with that. That is why I posted in one post at the start of the thread available right where needed rather than missing in various pages of chit chat. Equally it's useful to ask / answer questions all the same. TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831 ![]() ![]() ![]() |
I wish I had seen this two weeks ago, turned down the chance of a pair of Landrover additional driving lamps at very very reasonable price. The instructions stated that it was necessary to remove the centre dash panel, at that point I lost interest
![]() ![]() We don't like being old in the first place, so it doesn't take much to ![]() Richard |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 ![]() ![]() ![]() |
Thanks Steve,
Just fitted my new Kenwood Radio and your guide was invaluable, one thing, I took out the LR radio first and found that after I undid the torx screws I was able to pull the dash forward by putting my hands into the radio aperture and pulling the edges/top no levering required. Chris 2010 Defender 110 Station Wagon, Santorini Black. |
You can but it can stress the plastic, and certainly to be avoided if you have a painted dash centre.
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
Excellent write up
![]() Puma Defender 90 |
Glad people find it useful.
![]() ![]() β½οΈπ’οΈβοΈπ§°πͺ |
