Home > Maintenance & Modifications > Radio & centre dash removal guide (picture heavy)
Was this guide helpful?
Yes
95%
 95%  [81]
Maybe not sure yet
3%
 3%  [3]
No
1%
 1%  [1]
Total Votes: 85
Page 2 of 3 <123>
bob neville
Great write up Steve Thumbs Up
Slight hijack !!
GM
TD5 dash is very easy to remove.
First make sure you have some small containers to put the screws in so you can put them back in the same place.
Also, a small stubby cross head screw driver is useful.
Remove the two end caps, the drivers end is easy as you can see all the screws. Passenger end needs the LR oval removing with a fine screwdriver to reveal one of the screws. Remove both the plastic demister vents on the top (two screws each) and then the large cross head screws in the top - five in total I think.
The top of the dash will now come off, you may need to use a little force.
You can now see the three screws at the top of the centre panel, just loosen them as the centre slides off, and then remove the two bottom screws and the centre comes away from the dash.
If you need to remove the plate from the centre panel that holds the radio in there are spring clips that need releasing with a small screwdriver. The springs run along the top and bottom are do take a bit of time to release.
2013 Defender 90 CSW - sold
Post #192513 10th Dec 2012 8:48pm
Leeds - Very true. However this is the reason why I posted the whole thing in one post so in affect any chit chat makes no difference to the post at all as all the info is in one place at the top of the first page exactly where it's needed. Also gives a nice spot to comment on as well. However if the "useful" info was posted into a tech section minus the posts such as this that would be useful yes. Nothing but guides and info and nothing else at all. $W33T $0U7H3RN $UG4R
Post #192515 10th Dec 2012 8:49pm
farmer giles
excellent, clear instructions steve. Thumbs Up
i do agree with the old man from the north (aka Leeds) about having a technical library with no chit chat, though. Thumbs Up
Post #192656 11th Dec 2012 9:11am
Brilliant mate, well done ! Thumbs Up
The only thing I would add to help people is that all the electrical plugs are different so no need to stress over marking them all up
Post #192660 11th Dec 2012 9:22am
BigRuss
leeds wrote:
Nothing wrong with throwing ideas into the pot and see what the chief cook makes of it.
So my suggestion is a technical library but no chit chat such as this.
Brendan
you mean a read only technical libary Russell
2011MY 110 XS USW Black
Post #192672 11th Dec 2012 10:07am
And I don't know if you've noticed before but from the harness each plug appears in the positions you'd expect in relation to the positioning of it's switch on the dash. That makes it a lot easier. I only marked the electric windows down because I found removing these first allowed the dash to be freed more so gave more room to remove the rest. Also appreciate that XS owners with heated seats and headlight leveling would also have extra plugs / wiring behind there too.
Thumbs Up $W33T $0U7H3RN $UG4R
Post #192673 11th Dec 2012 10:08am
Anvil
Italy 2008 Defender 90 Puma 2.4 CSW Tonga Green
Re: Radio & centre dash removal guide (picture heavy)
custom90steve wrote:
1
Creating this guide has taken a lot of effort and work to complete. I hope it will help aid a lot of people
Hey Steve
I've just seen it. Crystal clear
Great Job ! Thumbs Up
Post #236202 16th May 2013 11:09pm
LR90XS2011
excellent very usefull thanks DEFENDER 90 TDCI XS,
Post #236207 17th May 2013 4:50am
I use the technical read only library on LR44 - about time there was one here Thumbs Up
Post #236218 17th May 2013 6:07am
Anvil - Thank-you hope it helped.
And yes agree with that. That is why I posted in one post at the start of the thread available right where needed rather than missing in various pages of chit chat. Equally it's useful to ask / answer questions all the same. $W33T $0U7H3RN $UG4R
Post #236252 17th May 2013 8:07am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I wish I had seen this two weeks ago, turned down the chance of a pair of Landrover additional driving lamps at very very reasonable price. The instructions stated that it was necessary to remove the centre dash panel, at that point I lost interest
Big Cry Big Cry Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #247682 29th Jun 2013 8:57pm
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
Thanks Steve,
Just fitted my new Kenwood Radio and your guide was invaluable, one thing, I took out the LR radio first and found that after I undid the torx screws I was able to pull the dash forward by putting my hands into the radio aperture and pulling the edges/top no levering required.
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #269101 24th Sep 2013 4:46pm
You can but it can stress the plastic, and certainly to be avoided if you have a painted dash centre.
Post #269122 24th Sep 2013 5:55pm
Nobby
England 2010 Defender 90 Puma 2.4 CSW Santorini Black
Excellent write up Thumbs Up _______________________________
Puma Defender 90
Post #269127 24th Sep 2013 6:15pm
Glad people find it useful. Thumbs Up Thumbs Up $W33T $0U7H3RN $UG4R
Post #269129 24th Sep 2013 6:16pm
Page 2 of 3 <123>
