Home > Puma (Tdci) > washer jets
steveandlooby
England 2008 Defender 110 Puma 2.4 XS CSW Java Black
washer jets
The front windscreen washer jet is missing on my 110. Stolen/yobo who knows. How difficult/easy is it to replace .....for someone who needs the dummies guide to reading dummy guides!
Steve
Post #23399 1st Feb 2010 8:28pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Steve they just push on.....i've super glued mine on as i lost it every time i went the jet wash Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #23402 1st Feb 2010 9:03pm
steveandlooby
javascript:emoticon('Embarassed')
Thanks Fekete - even I can manage that.
Post #23403 1st Feb 2010 9:10pm
mhill
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Bonatti Grey
Has anybody replaced or adapted the washer jets as i find them absolutely pants?
Post #23514 3rd Feb 2010 7:04pm
Grockle
Paul 55 tried washer propellors,but the water went everywhere but on the screen. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #23564 4th Feb 2010 4:51pm
Mr.Boots
Ireland
Mine broke off in the ice...dealer said its a dash out job...1.5-2 hours labour....for a bit of plastic??????
There is a bit of it left sticking out...can i push a new one on?
where can i get one online?
Post #23583 4th Feb 2010 10:32pm
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
Does anyone no if you can fit the D3 ones. They are a twin jet type I think
Allan
Post #23590 5th Feb 2010 12:00am
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
Did I read somewhere (here or elsewhere) that it was possible/easy to mod the washers so the hose actually runs along the wiper arm, squirting exactly where you wipe?
Or maybe I dreamt it! Rolling Eyes Mark
2011 110 XS DC
Stornoway Grey
Post #23593 5th Feb 2010 1:15am
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
I've read the same thread somewhere. I've seen it done with the old dash. http://www.reedx.net/landrover/mods/wipers/index.htm. I'm not sure how much trickier the Puma dash would make the job though. Being soft I've put off looking until the weather warms up. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #23597 5th Feb 2010 8:01am
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Think I've got to the bottom of this Grockle, used airplane props have now changed to submarine props much quieter and stealthier Laughing Cogito ergo sum
Post #23605 5th Feb 2010 10:19am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Wasn't it MSE (from memory) that ran his pipes along the wipers? Sounds like a good idea although I guess you'll get more freezing when it's cold. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #23629 5th Feb 2010 3:54pm
MuddyMarky
Also read somewhere about winding a thin copper wire around the header pipe (I think), then onto the washer hoses, so it acts as a heater to stop the freezing..... don't know, sounds like it could work. Mark
2011 110 XS DC
Stornoway Grey
Post #23632 5th Feb 2010 4:21pm
fekete
Hi and welcome Mr Boots you can get them on Ebay cheap and try to super glue the new one back on...if you need it straight away just pull the one off the back window for now....I think there about £4 also when mine came off the first time i thought it was broke but it just pushed back on NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #23647 5th Feb 2010 5:47pm
Laurie
You need a wire made of a resistive metal like nickel. Copper would just blow like a fuse.
Post #23653 5th Feb 2010 6:14pm
steveandlooby
Them bloomin dealers .....Mr Boots it appears the working mans interpretation of 1.5 - 2 hrs ripping the dash out is:
1. get AMR3025 from somewhere like here who deiver for the next day http://www.britishparts.co.uk/.sc/ms/bdd/ee/2395/WASHER%20JET
2. spend 30 seconds pulling the shaft away from the jet (I soaked mine in boiling water to help ease it out)
3. Push the new jet on to the vehicle
4. Treat yourself to lotsa lotsa alcohol with all the money you've just saved.
And thanks Fekete
Post #23657 5th Feb 2010 6:35pm
