Home > Td5 > Fuel Pressure Regulator: cheap fix? |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 |
If the leaking is only going out, and there is no pressure loss (no power loss) then the Orings will do the trick, but buy the best ones. cheap ones will not last. Augusto
Defender 110 TD5 2001 Discovery 4 TDV6 |
15th May 2013 12:47pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8162 |
last regulator i had complete was £60 ish, is your price gen?
yes its a easy job to do Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
15th May 2013 1:28pm |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 260 |
After calling around, the price I have seems fairly standard for a complete unit.
Hence I'm wondering whether this eBay valve I've seen for £25 is of use? ajps72 - no loss of power noted, thanks for the tip. Rob |
15th May 2013 2:20pm |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
Rob
Break down of parts are in pdf in my gallery Simon |
15th May 2013 2:38pm |
dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188 |
make shore you use viton o ring or may regret can be sorted in line
15th May 2013 8:06pm |
Thanks Simon. The part advertised on eBay appears to have no assigned number on your PDF file. It sits just to the left of the number 13!
Excuse my ignorance but what's a viton o ring? Cheers, Rob |
15th May 2013 9:13pm |
viton o ring used on TD5 fuel pressure regulator by LR
15th May 2013 9:30pm |
Many thanks for the info.
Cheers Rob |
16th May 2013 3:48pm |
