Home > Other Site Sponsors > English braid winch ropes available
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
New English braids winch rope available I will have a few at Harrogate
Let me know if anyone is interested
Kind regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #235534 14th May 2013 7:20pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
Sorry being a tart, what colour are they ? And price ? It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #235538 14th May 2013 7:27pm
big steve
They graphite grey and price depends on what diameter and length you want Thumbs Up
Steve 2015 2.2 tdci hardtop xs
Post #235539 14th May 2013 7:29pm
big steve
11mm 125ft ideal for warn or goodwinch lowlife winches £250 plus postage Thumbs Up
Post #235563 14th May 2013 8:20pm
jst
125ft of 11mm on a lowline winch - you sure it will fit? goldfish extended drum maybe but on a std lowline? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #235597 14th May 2013 9:04pm
big steve
Well im sure mine has and it's a std drum although I will double check tomorrow Thumbs Up
It may well be only 100ft but I'm putting 100ft 12mm on the front Thumbs Up
Post #235606 14th May 2013 9:22pm
jst
normally 80ft of 11mm on a lowline, 100ft will go on a large drum Goldfish
so 8274 front then? we normally run 125ft of 12mm on ext drums on 8274s. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #235628 15th May 2013 6:20am
big steve
No a lowline up front 2015 2.2 tdci hardtop xs
Post #235631 15th May 2013 6:51am
jst
100ft of 12mm on a lowline, thats good going, std drum? whats bunching like on use? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #235639 15th May 2013 7:30am
big steve
All seems ok I don't know wheather it's just me but the thought of using the thicker rope just give me more reassurance Thumbs Up 2015 2.2 tdci hardtop xs
Post #235644 15th May 2013 7:39am
jst
dont forget the thicker the rope the larger the min bend rad! so in fact a smaller dia rope is better at acute pulls! Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #235656 15th May 2013 9:10am
big steve
Yes I know what you mean jst 2015 2.2 tdci hardtop xs
Post #235685 15th May 2013 11:38am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
What is the difference in min radius bend between a 10mm and 12mm rope? Is it not 3 times the diameter on a fixed pin and 8 times diameter on a sheave.
so 6mm difference between 10mm and 12mm on a fixed pin. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #235729 15th May 2013 1:15pm
big steve
Sorry I stand corrected on my rope on my car its 100ft 11mm Embarassed
Sorry jst
Although still going to try a 12mm on front Whistle
Post #235902 15th May 2013 8:05pm
jst
off roaders gen to work on 7x factor for teaching etc.
its not so much the difference at the ideal bend radius, more so the fact you have it on a tighter than x7 radi when through 90deg out a fairlead (although large rad fairleads help (delta - tek - for example)) and the difference there that a smaller rope will take it better.
ropes that fail dont usually fail at this point, they fail soon after on a 'normal' pull in the area where the bend would of been at max load from my experience Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #235915 15th May 2013 8:38pm
