Home > Puma (Tdci) > Replacing Headlight bulbs |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
Are you sure ? I've had my headlights off three times now and from memory its the screws at 3 oclock, 9 oclock and the motorised one (connected to the height adjustment knob on the dash) at 6 oclock where adjustments need to be made. I just kind of figured it out so if I've done it wrong please advise ! |
14th Dec 2012 6:01pm |
skyeplumb Member Since: 22 Apr 2013 Location: Isle of Skye Posts: 134 |
I've just dropped a screw thru the slot - if you take the headlamp back out you can easily get access to retrieve the screw Series IIa Lightweight - Long Gone Discovery 1 300Tdi - Sold Defender 110 XS 07MY Utility |
11th May 2013 12:50pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2214 |
PIAA chrome extreme white . 4100 K no blue tinge and a perfect sharp bright white . Not cheep at 90 |
11th May 2013 4:55pm |
Doc P Member Since: 03 Apr 2016 Location: Midlands Posts: 565 |
Old thread, but Ive just shafted my alignment and my headlamp vertical adjuster doesnt work now either after I made a right fanny of bulb changing.
Shouldve read this first. |
27th Nov 2017 6:12pm |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 732 |
Replacement bits are cheap enough. Headlight fitting kit STC1614 contains most of what you need for 8. My local tyre/MOT garage adjusted the headlights for free.
27th Nov 2017 9:22pm |
Thanks Balvaig. My local garage fixed the issue FOC too (I hadn't located the screws at 6 o'clock in the slot properly - both sides!!) but my offside adjuster motor now just makes a buzzing noise. Will have to try and find it. The other works OK.
Ian |
28th Nov 2017 3:10pm |
From memory it is behind the bowl which is behind the light. Might just need lubricating. Worth switching the setting from 0-3 and back a few times and watch whether the headlight adjusts. Might also be mislocated. Pretty certain you will have to remove the headlight again to get at it.
28th Nov 2017 5:29pm |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 |
Make sure the adjuster is in the slot of the headlight ring and not behind it.
28th Nov 2017 6:22pm |
Thanks lads👍 I’ll wait till it’s a bit warmer and have another look.
29th Nov 2017 6:25pm |
