Home > Puma (Tdci) > a request to fellow puma owners
Ed
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Zermatt Silver
Hi,
I'm having a small issue at the moment with the nearside front brake hose and the route it takes back...
Could fellow Puma owners take a photo for me to reference against as I believe mine is incorrect.
Long story , but the short version is the coil spring has worn through the pipe resulting in failure....... Sad
Cheers all!
Ed.
Post #23425 2nd Feb 2010 11:05am
Grockle
Re: a request to fellow puma owners
Ed wrote:
Hi,
Cheers all!
Ed.
can't you get the dealer to sort it Ed ? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #23426 2nd Feb 2010 11:15am
Ed
it's in the dealers currently...
I am just not convinced that the pipe was in the right place to start with. This after being in the dealership for extended periods of service and work around the particular area........
Just wanted to compare a few photos to cure my own curiosity really.
Post #23427 2nd Feb 2010 11:25am
K9F
Similar Issue.
I've just had a recent saga with ABS/TC warning lights. Vehicle was in several times. This was attributed to an incorrectly routed outlet valve cable 'since manufacture.'
The aircraft I work on were manufactured by Mexicans who were more often than not intoxicated (well that's the rumours on the shop floor) hence the different build qualities.
I suppose anyone can make an error and it would be a boring world without them! Obviously not every nook, cranny, nut, bolt or washer can be inspected during Land Rover's quality process.
Upshot is it is quite feasable that your pipe was indeed routed incorrectly, the fact it has been sorted one would assume 'free gratis' under warranty should pacify you and allow you to sleep at night.
Happy Days. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #23432 2nd Feb 2010 11:45am
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #23434 2nd Feb 2010 12:28pm
Ed
Thanks for the posting , I include one of mine from the front showing where the pipe has been worn by the base of the coil spring... It would seem that it could be rectifed by stopping of the steering lock bolts.. It was my view that the pipe should have taken a different route though...
[/img]
Post #23440 2nd Feb 2010 1:05pm
K9F
Extra Pipe.
Fekete me old Northern Mucker,
Like you I haven't alot on today either, whilst comparing yours and Ed's photos it appears you may have been 'diddled' out of an extra pipe. It appears Ed's got an extra rigid pipe! Any ideas what this may be and why you ain't got one? Hate to think you 'dipped out!' If it wasn't for the fact it's peeing down here and mine is a mile away I'd go see myself if I got one!
Post #23441 2nd Feb 2010 1:16pm
Eduardo
Humm,
Fekete's and Ed pictures refers to a different wheel. Im not sure but I think both sides are not equal in the pipe routing. I will check today mine to see the configuration.
I found some old pictures of the brake lines (mine doesnt have ABS and TC)
Cheers Eduardo
Post #23444 2nd Feb 2010 2:04pm
K9F
Same Wheel Pictured.
Eduardo,
Fekete's and Ed's pictures are of the same wheel. When sitting in the vehicle it is the wheel that is at the front on the left. Hope this clarifies.
Post #23446 2nd Feb 2010 2:17pm
fekete
Yep front left I'm thinking Traction control / ABS..What else could it be ??? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #23449 2nd Feb 2010 2:44pm
K9F
What TC/ABS not standard?
Fekete,
Thought you had TC on yours! I thought TC/ABS was standard on 'em all. Shows what I know! Need to do a bit of swatting (no flies on me by the way).
Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #23450 2nd Feb 2010 2:49pm
fekete
No me old mate...No TC or ABS just plain old Brakes Big Cry
But i've got 17 stone to push it with...if that don't work im faarrrrked NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #23452 2nd Feb 2010 2:54pm
K9F
TC/ABS
Don't want to hijack this thread but heard good and bad things about TC/ABS. I cannot turn mine off, off-roaders have mixed views if this is a good or bad thing.
In my limited experience I do know that having taken my mind off the road just before a hairpin before the snow were it not for TC/ABS I would have done some serious damage to the Defender and my pride for being such a biff!
Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #23454 2nd Feb 2010 3:04pm
Eduardo
Oops, you are rigth, same wheel looking from different side (I need vacations).
Looking the photos, Ed's brake pipe looks shorter I thought.
By the way TC/ABS were not standard at least in Chile. When I bought mine TC/ABS was not available Big Cry Big Cry.
Cheers Eduardo
Post #23456 2nd Feb 2010 3:08pm
fekete
K9 went out in one last week with TC/ABS and the TC was working all the time...I think i'd rather have it than not.. but when i got the Defender it was the only one about in that color and with it being my first i thought they all had it as standard Embarassed
To be honest i was to excited to care Rolling with laughter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #23458 2nd Feb 2010 3:16pm
