Home > Td5 > Gear ratio's on a 90.... |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6097 |
I did it on my 110 a year or 2 back.
Yes, 1st gear is a bit higher; on the flat not noticible, but on a steep hillstart you notice it. If i had my 255/85's on then i would slip into low range to pull away on steep hills, but on the standard 235's low box isn't needed. If you've got a nice torquey engine (i've got a VGT turbo too) with good low end grunt, you find you don't have to change gear as much either, just leave it in 3rd or 4th. Bear in mind this is a lardy 110 station wagon with full cage, so it's pretty heavy. A much lighter 90 this problem isn't going to be as bad. But in all, i'd do it again (in fact, will be on my 90 whenever a good priced 1.2:1 box turns up). makes for cruising much better, and a bit quieter too. |
7th May 2013 6:02am |
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 152 |
Jamie, Got a surplus 1.2 LT230 here, 28 tooth, came off Tim's V8 as far as I am aware really low mileage. Regards Les |
7th May 2013 8:11am |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 158 |
You will find its ok. Lets face it. Singapore is indeed town driving everyday. I get stuck in traffic all the time. I've got a 1.222 swap and I'm way much happier. If you don't tow, it's fine. Uphill down hill it's ok. Serious. You've got a remapped engine, so I assume tis a td5. I'm happier with this setup over a 1.41 ratio. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
7th May 2013 10:49am |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1423 |
Paul,
Its something I contemplated long and hard about. I even had it booked in at Ashcrofts and then got cold feet I do a bit of towing, and need to be able to as required, exhaust gas temp was main concern In the end I decided it just wasn't worth it. Took out the cat, fitted a louder stereo and I'm happy Try pulling away in 2nd gear, it will give you an idea as to what 1.2 transfer box is.(it'll take some getting used too ) |
7th May 2013 11:10am |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Thanks for the replies, I don't do much towing and if I did it'd only be a light load of logs but I probably need to give it some thought, my brother in law had it done from new and swears by it, I'll drive his next time I'm over there.
On a side note... Are Barbell-Jim and Diesel-Jim related?! |
7th May 2013 11:32am |
It's not quite as bad as second gear pulling away... maybe 1 3/4 gear
Nah, unless he's ginger and ugly as well? In which case i've got an uglier brother.... |
7th May 2013 2:12pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
Don't have any problem with 1st gear following a swap to a 1.2 box in my 90, and I'm on 265/75 tyres too. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
7th May 2013 2:35pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
It's just like driving a disco 2
Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
7th May 2013 2:55pm |
Not quite - a standard Disco 2 is on smaller tyres, which reduces the gearing significantly. Darren
7th May 2013 3:04pm |
Well ok lol ours is on 265 75 16s sorry 2015 2.2 tdci hardtop xs
7th May 2013 3:25pm |
Luismi Member Since: 04 Nov 2010 Location: Cotswolds Posts: 178 |
This is quite a subjet as i been trying to figure it out wihich will be the best ratio for my TD5, i own a puma before and i intend to achieve a similar thing
To fix some point, changing the transfer from 1.41:1 to 1.211:1 with the standard 3,54:1 and 31 tyres at 800 RPM we will go at 8.17Km/h instead of 7.01km/h in the original setup, and as Diesel Jim says you will notice on hills. of Fifth gear let say at 3000 RPM you will go at 134.88 Km/h instead of 115.85Km/h in this case to compare with a PUMA that has oviously different gearbox ratios will go at 139.98Km/h this means that your car with the 1,211:1 will go 3.64% lower than a puma. Hope this helps |
7th May 2013 7:01pm |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 |
Or use an overdrive, 28% higher than standard so 30mph/1000rpm compared with standard 23mph/1000rpm so 60mph is a nice relaxed 2000rpm. Just higher than 6th on a Puma but you get to keep the standard gearing as well
7th May 2013 8:20pm |
Yobbie you have the overdrive with mechanical actuator or electrical?
That is actually a good point as may be the most cost effective and versattile way to have the most of your ratios |
7th May 2013 8:46pm |
Mechanical as an extra gear lever it's a Roverdrive now known as Roamerdrive.
7th May 2013 8:54pm |
