Home > Puma (Tdci) > Removal of trim
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
Removal of trim
Does someone know if I have to remove parts of the lower dash to remove the trim around the gearbox? Doing Dynamat all over at the moment Smile
Thanks m
Post #224204 2nd Apr 2013 7:31pm
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
Is this the trim you mean here? if so then no, just remove the fuse box and relays. Thats on a Td5, can't comment on the Puma.
Post #224209 2nd Apr 2013 7:47pm
Killer90
Site Sponsor
Just remove the torx screws on the lower part of the dash and pull it away as the rubber is tucked up there to reomve Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #224211 2nd Apr 2013 7:56pm
100inch
Thanks killer90!
Will do.m
Post #224283 3rd Apr 2013 5:48am
First90
2010 Defender 90 Puma 2.4 HT Alpine White
100inch do you have a Puma Defeder?? I have been warming up to this dynamat idea but was also wondering how to get that mat that runs along the front of the foot well and under the dash out. Had a good look over the weekend and it appeared tricky.
How extensively are you laying the dynamat? I am thinking just the front footwell and under the front seats.
Post #224459 3rd Apr 2013 9:21pm
100inch
Yes I got a 110 Puma. Just finished the Dynamat around the front seats today. I removed the trim gearbox- tunnel/footwells but left the trim going up on the bulkhead. Will post some pics tomorrow.m
Post #224538 4th Apr 2013 10:06am
First90
Hi 100inch, any update on the results of installing dynamat in the front seats/footwell area??? has it been worthwhile?
Post #232353 2nd May 2013 11:31pm
Jez676
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Without going into technicalities of sound absorption Dynamat is excellent at taking low frequency vibrations out of panels. In order to cut other airborne frequency noise out such as road noise, then there needs to be open or closed cell foam layed over the Dynamat, then your carpet or Hardura. Dynaliner is the foam that is designed by the Same manufacturers of Dynamat. It is good but expensive however there are cheaper alternatives. If its going to get wet then it needs to be a closed cell foam. Open cell has better sound absorption properties and can be used on the roof and rear panels down to the arches.
There is a bulk buy Dynaliner offer on the forum, hope this helps Shocked
Post #232574 4th May 2013 12:05am
Jez676
The Dynamat is Simon or SGH is his name on the forum.
4 sheets of this is enough to go over the whole roof and the rear floor on top of your Dynamat. It's cheap and works!
http://www.pipelagging.com/armacell-armafl...6_179.html
Post #232575 4th May 2013 12:29am
100inch
Sorry for the delay! I have done the load area, front and back row seats all over plus front footwells. Yes, there is a difference but I thing I will do the roof ASAP. I would definitely recommend doing it but it takes quite a bit of work if you want it done properly.
Post #234008 9th May 2013 8:12am
