Home > Technical > Heater control knob
AndrewS
Heater control knob
Seems a bit silly complaining about a heater on a defender but here goes.
Normally in winter we have the heater set somewhere between the red and blue markings on the dial. However this last week something has broke. In this position the temperature would be either hot or cold, so if its cold we turn it up one click at a time. It goes something like this. Colours indicate where the temp setting is positioned
Cold 'click up'
Cold 'click up'
Cold 'click up'
Cold 'click up Max'
Hot Hot Hot 'click down'
Hot 'click down'
Hot 'click down'
Hot 'click down'
Hot 'click down'
Hot 'click down'
Hot 'click down'
Cold Cold Cold
So I no longer have the ability to fine tune the temp its either very hot or very cold.
Does anyone know if there has been any issues with the temperature control device Question
Post #23157 29th Jan 2010 9:02am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Maybe it's not the same, but yes, I found mine to be a bit binary too, it's either cold or hot, not much in between. It's been like that from new, so I thought it was by design Smile
i play with the other controls instead to get the temp I want.
Post #23159 29th Jan 2010 9:21am
bob neville
Andrew
I had to have my heater control replaced a few months ago when it jammed solid.
Apparently the control mechanism is a complete unit with the temp and direction controls integrated.
It took a couple of hours to have the unit changed as it has to be calibrated once fitted.
Bob
Post #23160 29th Jan 2010 9:23am
AndrewS
Thumbs Up Calibrated eh.
Perhaps mine needs re-calibrating Question
Post #23164 29th Jan 2010 9:49am
bob neville
Could very well be.
I thought it was a 5 minute swap over for the new unit but that is certainly not the case.
The original broken unit just seemed to give boiling hot air or cold, the new calibrated unit has varying temps throughout the range.
Bob
Post #23167 29th Jan 2010 10:07am
CapeLandy
South Africa
mine has a cable operating the valve so I can't see how anything could be calibrated. Maybe ours are simpler here for our mechanics to undershtand . Wink
Post #23168 29th Jan 2010 10:09am
bob neville
I could be wrong but I think the calibration is of the cable and whatever controls the heat and flow.
I don't think it is an electronic calibration as such.
Bob
Post #23180 29th Jan 2010 11:22am
spudfan
Ireland
The cable is held in place by a little plastic clip. If it breaks the cable cannot be pulled by the lever as it just moves up and down with the lever. With the clip in place the outer sleeve is held rigid alowing the lever to move the cable in the sleeve to open and close the valveTo check visually, take the plastic covers off the levers. Remove the side dash by undoing the screws and sliding it off over the levers, and check that the cable is held tight. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #23201 29th Jan 2010 6:13pm
K9F
Mine's exactly the same as above. Have become accustomed to it and with a little 'jiggery pokery' can get the temperature I desire. Only ever use the first third of the dial from cold to fully hot to get desired temperature. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #23204 29th Jan 2010 6:38pm
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
Mine is just hot or cold with nothing in between and I know someone else who has the same.
Does this mean I should get it sorted under warranty? MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #23244 30th Jan 2010 6:00pm
